One of those Vs questions
Posted by: garyi on 07 February 2003
Now its been a while, I feel an upgrade thang coming on.
It would seem through close observation that I am now playing mostly records and would be looking to upgrade in this area.
Cheaply.
So I was thinking of a stageline(?) or an out side of the preamp phono stage.
I understand this would need to be powered via a *cap.
So would a 102 & 180 with stageline-cap sound better than a 102/180/Cap with internal boards?
Bearing in mind I can't afford another cap at the moment.
Any thoughts welcome.
Posted on: 07 February 2003 by Paul Ranson
I don't think you should bother with just a Stageline.
Work out where you want to end up and take a step there.
Paul
Posted on: 07 February 2003 by kan man
Suggest you decide whether you prefer the Linn or Naim approach to a maxed out LP12 and head in that general direction.
Assuming you have a Valhalla I found more improvements were to be had from TT power supply than phono stage. Check out a Lingo/Armageddon. I prefer the Naim approach btw.
Steve
