No Signal On Coaxial Digital input #1
Posted by: iknowwarren on 14 January 2008
I have been using the AV2 for a year now and had no problems at all until last week. Now I am getting no signal from Coaxial Digital input #1. All I get is just get no signal flash up and 3 flashing bars and no audio but if I put it in Coaxial Digital #2 it works fine. I have not change anything on my setup or added anything components. It has just stop working.
My version of firmware is AVCO106 F658, if I update my firmware will this solve the problem.
I have read a lot the threads to see if anyone has solved the problem and it seems this problem is not uncommon but no answer has been posted. Please help.
Warren
Posted on: 15 January 2008 by AV@naim
-what source are you using?
sounds like the coax #1 is faulty
Posted on: 15 January 2008 by iknowwarren
Thanks for the response. The source is a Rotel DVD player but it doesn't matter what source I use. The funny think is, if I leave it for await it will sometimes work but as soon as I change the DVD chapter it is doesn't. I guess I need to send it to Naim
Posted on: 15 January 2008 by Manu
If i am not wrong you are scheduled to send me the unit next week. Winker
Posted on: 16 January 2008 by iknowwarren
I will be sending it to you. I hope you will be able to fix it. I made a slight error, it coax #2 that doesn't work but coax #1 works.
