If Naim did not exist, what would you have?
Posted by: Andrew Randle on 16 May 2001
Andrew
P.S. I would go for a Resolution Audio CD55, DNM 3C Six, 2x DNM PA3S, Living Voice Auditorium OBX.
Andrew Randle
2B || !2B;
4 ^ = ?;
[This message was edited by Andrew Randle on WEDNESDAY 16 May 2001 at 12:51.]
LP12/Cirkus/Lingo/Aro/Asaka
...would have ended up...
LP12/Cirkus/Lingo/EkosII/Asaka
and my amps:
Crimson 610/640D monoblocks
(chosen over Naim, but a difficult decision to make)
and my speakers:
Neat Petite III/Gravitas/Stentor I sub
all on a pile of lovely Mana.
If Quad never existed then there would be no hi-fi!
Bob.
i guess i would hunt down an Onix OA-20 or Cyrus 2 or 3 (my previous amps before I got hooked on Naim)
My CD-player would probably be a Rega Planet or something like a cd-63KI. who knows..
Greetings,
Alco
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
I would still have my - veery hard earned - retirement nest egg wallowing in a high interest account somewhere or other.
I am a Yorkshireman - Born To Be ..... Cautious?
As it is, I'm still pleased that I took the decision to blow the lot last year on a rather expensive (let's face facts here Naim stuff is expensive right?) system and still I have no regrets at all.
Why compromise?
Why wait?
I wish you all luck with your endeavours elswhere but for me it is Naim all the way!
Now...'bout those new speakers.....
P.
you're right,I made a little mistake.
ehhh, my FINAl non-naim based system,eh....
man,that's hard to imagine...ehhhh.....
I give up..
Were I rich, without a question I would buy Spectral electronics and run them into Avalon loudspeakers. The best stereo I have heard was comprised of this gear. (Keep in mind I have not yet heard a CDSII / 52 / NAP 500 front-end).
Were I a little less rich, though rich all the same, I'd also consider some McIntosh gear. Whew those big monoblocks sound good. I'd probably couple them to Wadia digital gear and Vienna Acoustics or ProAc loudspeakers.
A little further down the ladder, but only a rung, I'd go for SimAudio electronics coupled to either Rega (Jupiter) or Arcam (Alpha 9) digital gear, and Vienna Acoustics or ProAc loudspeakers.
Fortunately, I do not need to make that choice . . .
Hence my final system would consist of:
Linn LP12 Mk 2 [Replacing the LP12 in 1996, this surprise development includes a custom made direct drive motor and sensors that feed forward both noise picked up from the deck and accelerations of the Ekos III arm].
Linn Boingo [Microprocessor controlled active suspension for the LP12 Mk 2].
Linn Linnk Mk 7 [Phono pre-amp].
Linn Dingo [Digital phono processor that makes use of the feedforward data from the LP12, as well as applying user-adjustable real-time glitch/hiss filtering and phase correction].
Linn Karik Mk 1 [Without the CDS to inspire them, Linn finally introduce their first CD player in 1998. Linn are particularly proud of the fact that they've managed to make it sound as good as their prototype (codenamed "CD12") at 1/4 of the price the CD12 would have cost had it been put into production].
Linn Konga / 3x Activ Kaboom [active pre-power combination].
7x Linn SuperKap [You can guess what these strangely named Linn innovations do].
Linn Isobarikan [Replacing both the Kan Mk. 6 and the Sara Mk. 13, the Isobarikan makes the Kan sound slow, and the Sara bass-light].
PS The electronics, of course, are all on Linn Ku-Stands ![]()
--Jeremy
"Time is an illusion - lunch-time doubly so."
[This message was edited by Sproggle on WEDNESDAY 16 May 2001 at 23:17.]
On a more serious note:
Meridian CD
Keep the Gyro
Michell Orca pre and Alecto monoblock power amps
Kef Reference 4 speakers (or Maidstones if I was DBL rich!)
Good game, good game...
Rega Jupiter, Cursa pre, Exon monos and Spendor S-100.
Not so much because it's the next best thing out there but because it'd be the next best thing at the dealer. Bonuses are that I'd be at the top of the upgrade path, would have spent less money and there's no power supplies to worry about.
Maybe a Roksan TMS turntable and a Meridian 588 CD player as well.
Answer:
Alternative therapy.
Either that or a breakdown!
Next.
I love the idea of Jonathon sitting in front of a stack of Marshall amps (don't get the turntable too close, yah don't want any feedback!).
Sproggle also has a good point. Without Naim, Linn would probably be a very different beast.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
The amp is Class AB with 9 parts per channel (excluding attenuators) and a signal path of 32 mm including parts. It has an external power supply, as do the cd transport and no oversampling or digital filter DAC.
Does anyone know the details of the amp circuit?
--Eric
John
1985, Radford Hi Fi, Bristol. We sold more Naim amps than any other make. We had fewer Naim amps returned than any other make.
I don't think luck had much to do with this fact.
Bob.
could the problem be Saras, when I had a Brief interlude with Saras the 250 would get very hot if you pushed it and I quite often got it switching off. I cant see that this does an amp any good , Mr Pig uses Saras , but never experienced a problem when he had Kans.
I have heard the Pig amp and can confirm that it's sick. I've also heard the volume at which Mr Pig plays the Saras and can confirm that a 250 should not keel over at those volumes even after protracted listening. FWIW, the problem we're talking about sounded to me like a slightly bad connection somewhere in the audio chain, which was only noticable during periods of either sustained, strong clear notes or mid-bass. I wonder if it's a simple matter of a connection needing to be resoldered?
The left channel of said 250 is fine, which makes me wonder if it could be something like a bad connection behind the RHS speaker outputs or even the preamp inputs - can anyone comment?
John, who is sitting on the fence on this matter.
Valves that are designed to distort at low gain settings and with a very narrow frequency range, through 12inch paper celestions with equally bad frequency extremes.
As a guitarist for over half of my life I will be the first to say that guitar amps and hi-fi are completely incompatible and incomparible.
A head and a stack of two 4x12s would make DBLs look wussy though! ![]()
Thats why we have a service department! I believe this unit is quite a few years old and may be well overdue for a check up. I guess the amp is being used with a standard naim pre-amp and psu at the front? and all cables are standard.
Martin
[This message was edited by Martin Payne on SUNDAY 20 May 2001 at 12:56.]
or depression ![]()
Andy.
Andrew L. Weekes
alweekes@audiophile.com
