SNAPS
Posted by: Andrew L. Weekes on 24 May 2001
Excuse my ignorance here.
Is there only one type of SNAPS PSU, or two?
Others have commented on converting them to dual-rail (as per HiCap), so I assume there's two sets of regulators in each box?
How was each regulator used in the context of an early system (i.e. before .5 mods)?
I've seen one s/h at an excellent price, and was going to buy it as a more aesthetically pleasing supply for my prefix, in place of my DIY-cap, as I want to use that in my second system.
The price means I can have it serviced / modified and still end up with a cheap PSU.
Andy.
Andrew L. Weekes
alweekes@audiophile.com
Posted on: 24 May 2001 by Mike Hanson
There is a SNAPS2 that has two regulators inside. It was originally intended to supply a separate component via a separate socket (I'm not sure what at the moment).
Sometimes it says SNAPS2 on the back, but most times you have to remove the case and see if there are two regulators inside. Also, if there is a 5-pin DIN socket on the back, then it's already been converted.
I prefer a dual-rail SNAPS2 over the old Flat-Cap. The new Flat-Cap2 is better.
-=> Mike Hanson <=-
Posted on: 24 May 2001 by Chris L
_____________________________________________
IIRC it was to power a NAXO.
Chris L
Posted on: 24 May 2001 by Andrew L. Weekes
That explains everything.
Andrew L. Weekes
Posted on: 24 May 2001 by Milan
I have a very old snaps.
I am not sure if it has 2 regulators but has 2 sockets for pre amp or naxo. Does this still allow dual railing and if it is from one regulator what is the benefit?
Milan
Posted on: 24 May 2001 by Eric Barry
I had a Snaps around 4000 that had two regulators. As originally supplied, one fed socket four, one fed socket two. That way you could send power to your 32 and your Naxo. I think they are all like this, as the Naxo has been available since 1977.
However, you can rewire this so that instead of supplying two sockets with single 24V rails, you can supply a single (5 pin) socket with two 24V rails, like a flatcap with a larger coil, or a hicap with a smaller one.
--Eric
Posted on: 25 May 2001 by Andrew L. Weekes
My offer has been accepted, and it's a later one with green LED as a opposed to red, so if I'm luck it can be converted to 'mini HiCap'.
Bit of a bargain @ £70
Andy.
Andrew L. Weekes
Posted on: 19 October 2002 by calum scott
I have an old 42 and SNAPS lying unused at the moment and wondered if the SNAPS would power both the pre and a headline.
The SNAPS has definitely not been modded in any way so is not dual railed.
Appreciate any thoughts. Might help me get that second system up and running with headphones.
Thanks,
Calum
Posted on: 19 October 2002 by Manu
Calum,
Yes you can. You will have to do a mod for connecting the SNAPS to Headline:
You have to buy a SLIC, it's the cable. But this cable has a 5 pin Din, you will have to ask for a 4 pins Din. This cable is made to connect a Hicap to the headline, but it uses only one rail of the Hicap.
Mike,
I agree with you, the SNAPS is one of the best kept secrets in Naim products.
Emmanuel
All opinions are my own, and reflect those of the organisation i work for, even if not stipulated.
Posted on: 20 October 2002 by calum scott
Thanks for the reply. I'll have a word with my dealer and dem the headline and see if I can get this up and running.
calum
