USB vs iPod Touch through the DAC
Posted by: Jan-Erik Nordoen on 18 March 2010
I've compared playback from the iPod classic and USB; the latter wins hands down.
Has anyone compared USB and iPod Touch? I'm wondering if the solid state memory in the Touch brings it closer to USB playback.
Jan
Posted on: 18 March 2010 by banjer1
Do you mean you have compared the sound on a Naim (Uniti or ?) from an ipod using the designated ipod cord versus the ipod into the USB?
I thought that Naim doesn't recommend using the ipod into the USB. I also wonder which DAC you are using in that situation if not both??
Please fill me in. I was not impressed with the ipod cord on the uniti, so I didn't even buy one. I'll go with a ipod raw data extractor into the uniti if I want the ipod to be my source.
Posted on: 18 March 2010 by Naijeru
I haven't run an iPod classic through my DAC so I can't compare it to the Touch but I can say that the Touch doesn't compare to USB.
Posted on: 18 March 2010 by Keith L
The iPod Touch through the Ndac sounds very ordinary, not really good enough for serious listening.
The usb stick on the other hand is extremely good, up there with the best digital sources I have heard. It's a shame the controls are so rudimentary and in most cases, haphazard.
Posted on: 19 March 2010 by pcstockton
really??????????????? really? That big of a difference?
You were playing the EXACT same files??
Ill have my own go during my home demo a week from this saturday. But i am guessing there is ALOT of hyperbole going around the forum these days.
Alot of usbs better than others, Ipod touches killing classics, wav destroying flacs, and all too much Amarra and Pure Vinyl (how bad does iTunes f up the music????).
I will judge myself and would be surprised if these differences are close to meaningful, if existent at all. Im sure ill report something or other.
Of course the beef will be that I only run $10K worth of kit (new), and a "much more resolving system" is needed to hear what others are making up and pulling out of thin air Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes Roll Eyes
Posted on: 19 March 2010 by Keith L
Oh yes.
Posted on: 19 March 2010 by MartinCA
Look forward to that! My system is down the bottom end of the Naim hierarchy, but the differences between a USB stck and an iTouch into a DAC are still very clear.
I don't fully understand why there are these differences, but my lack of understanding doesn't make them the difference any less real.
Posted on: 19 March 2010 by Steve Cox
Can I just try to clarify something for non-experts such as myself?
When you play music from an iPod, etc, are you feeding the signal that would normally go to the headphones into the Uniti instead, or are you somehow reading the music file in its original digital form, which is what I understand the Naim iPod cable allows you to do? If the former, then I can completely understand the difference in sound quality, but if the latter, I can't understand it at all.
Posted on: 19 March 2010 by Jan-Erik Nordoen
Sorry if not clear : it was the Naim DAC, using an iPod Classic with the iPod cable plugged into the front USB socket.
Yes, ripped using Exact Audio Copy
The Naim standalone DAC is the first to (officially) access the digital data on the iPod (5th generation and above), iPhone, iTouch & iPad. In the Uniti, the iPod input is analogue.
On the standalone DAC, from an iPod/Phone/Touch, the USB socket accepts data sampled up to 48 kHz, whereas from a USB stick it's up to 768 kHz. So, with a CD-quality WAV file (44.1 kHz), I would have expected similar results, since it would seem that the DAC is simply receiving digital data from a solid-state memory in either case (USB stick or iPod/Touch/Phone). I asked Emmanuel Lequere from DIMEXS (Canadian Naim distributor) about this, and his view is that with the iPod/Phone/Touch, the digital data is going through iTunes first, compromising the sound. Apparently there is no way around this.
Posted on: 19 March 2010 by Naijeru
Leaving aside the issue of hyperbole, which I agree there is a lot of, why is it so hard to believe that different sources would sound noticeably different through the DAC?
My iPod Classic vs USB comparison was on the DAC with its supplied powercable (no Powerline), no XPS2 or 555PS (one day perhaps...) feeding an Audiolab 8000S integrated amplifier. Interconnects Chord Indigo. Speakers were a 5" two-way design using Morel components.
[Hyperbole OFF] With the iPod : good sound, not very involving, fine for polishing the cutlery or trolling the Naim forum Big Grin. With the USB : great sound and impossible to do anything else.
What kind of files were these? WAV presumably?
I am not saying there isn't a difference. But the language used is making it appear as though one source through the Naim DAC sounds like a 5i and other make it sound like a CDS3.
I doubt these extremes exist, with the DAC. I am guessing gradually increasing the quality of the transport from an iPhone all the way up to a CDX2 will bring incremental changes of gradually diminishing value.
Are you positive the Classic iPod you are using is actually supported by the DAC?
Yes ; 16/44.1 ripped with Exact Audio Copy
USB stick replay through the Ndac requires wav files in the route directory. Nothing else plays.
With the iPod : good sound, not very involving, fine for polishing the cutlery or trolling the Naim forum . With the USB : great sound and impossible to do anything else.
Exactly - but digital iPod into DAC still much better than the analogue iPod into pre-amp.
You can switch off the ability for iTunes to control the volume in the preferences/devices. This improves matters, and I think it then provides a clean digital feed.
From earlier discussions on this forum there seem to be differing views, some saying that the DAC isn't immune from jitter from the source (which I am not convinced by) and some saying that once the music is being streamed, it is vulnerable to noise, especially in the SPDIF interface in the iPod or Airport.
I wish someone could provide an authorative answer on this. But all I can report categorically from my DAC is that identical files sound less good from the iPod or Airport than they do on the memory stick. This is not something you have to switch back and forth to hear - it is quite obvious.
I know this isn't exactly what you meant, but more generally I think it can sound anywhere between those two extremes, depending on what system you have. In a system with 555 tech and XPS power and all the expensive cables it could well sound like a CDS3. In a system with an old Nait, and no gismos, it will sound like a 5i.
By the way, I think this is brilliant. You can build a system around it. You can plug it into your entry level system , and it can still hold its own along the upgrade path onto top end systems too.
Yup. It's a 5th generation model.
Posted on: 19 March 2010 by likesmusic
Jan - when you play from the iPod, does the iPod volume control affect the level?
Posted on: 21 March 2010 by Jan-Erik Nordoen
When I plug the iPod into the DAC (iPod on or off), the screen switches to 'OK to disconnect'. I can't control anything from the iPod ; it simply plays whatever was playing when I last used it or when I plugged it in.
Restoring the iPod to its factory settings through iTunes doesn't change this behaviour.
Any thoughts ?
Thanks,
Jan
Posted on: 21 March 2010 by pcstockton
Dont the DAC's front panel buttons take over when the iPod is docked?
Is there a way you can test with a friend's iPhone or iTouch?
-p
-p
The DAC's controls take over for USB stick replay ; but not for (my) iPod. Not sure if this normal behaviour.
Will try with a friend's iPhone.
Thanks for all your suggestions !
Posted on: 21 March 2010 by Keith L
I'm sure I could use the screen to control my iPod Touch when it was connected to my Ndac. Mind you it sounded so uninspiring playing back Apple Lossless that I didn't give it much time. Mac/HiFace into the Ndac is considerably better.
Posted on: 21 March 2010 by MartinCA
-p
The iPhone controls works as normal when its plugged into the DAC. Not sure about the iPod though - will test when daughter returns with it. I would have expected it to work as normal too.
