DVD5 Playing Up
Posted by: Neill Ferguson on 08 April 2009
can anyone tell me how I get a picture output through my dvd5 as I can't seem to get a picture out of it. I keep getting a fuzzy screen, I am using an hdmi cable is there anyway to get a direct fed to check to see if it's a fault or not?
Posted on: 10 April 2009 by SC
Did you get sorted Neill....?
It gets more and more quiet in this room, hey....
Steve
Posted on: 12 April 2009 by Neill Ferguson
na mate no one has helped me Confused
I just need to know how you get a signal out via an output so I can check the picture is working.
Posted on: 12 April 2009 by Massimo Bertola
Hi,
I'd love to help but I'm not sure I cought the problem right..Once in a while I post a silly reply because of a language gap..
Anyhow, when I bought my DVD5 I wasn't getting anything because of previous settings; so, have you just tried to reset it (press and hold the >clear< button, unplug and replug it? You should at least get a green Naim logo.. This helped in my case because the unit had been usedf for music replay and all the videos were off. before I reset it I couldn't get anything, and if you haven't a picture you can't reach the OSD.
Can you give any more detail?
Massimo
Posted on: 12 April 2009 by Adam Meredith
Contact your retailer or Naim Customer Services direct for advice on resolving this.
The forum isn't monitored regularly for such enquiries but you will always obtain definitive advice if you go direct.
