Royd Speakers - NAIT 3
Posted by: Muzza on 17 September 2001
1. Do they have a WEB site, as despite trying I am unable to find one ?
2. Will a NAIT 3 drive the Squire and Minstrel OK ?
3. What are the respective merits of the Squire and Minstrel ?
Your thoughts appreciated
Royd used to be at www.royd.com - a page that was developed and maintained by their Canadian distributor. However, this site is down as it is about to be rehauled (due to the introduction of a new range).
Yes a Nait 3 will drive Royds.
I don't know about the Squire, but the Mistrels are very very good. The problem is that both models are now discontinued and making way for the new range - which sadly starts at about £800.
Andrew
Andrew Randle
2B || !2B;
4 ^ = ?;
I've never actually owned a pair of Minstrels but I've listened to them a lot with various friends, etc. In a nutshell (no Austin Powers jokes please!) they're an extremely good speaker for the money and would work really well with a Nait.
They don't do really deep bass but what they do produce is very musical and can be improved if you set them up properly in the room. Half a foot or so away from the wall and spikes placed in screws which are screwed into the floor.
No experience with the Squires sorry.
Hope that helps. Jay
Heard this combo while buying current 92/180. Even in a relatively big room (30 x15 ft) they went plenty loud enough on the end of a Nait5. Our room is considerably smaller (15*12 ft) and anything above 9 O’clock is going to seriously annoy the neighbours. Also did a Minstrel-SBL comparison and while the SBLs were obviously superior (better controlled bass and more open mid-treble) it wasn’t enough to convince me to change the Minstrels in the near future.
Simon
The Squire, which was designed to be more compatible with Japanese A/V amplifiers, is more efficient than the Minstrel. However, I feel the Minstrel is a better speaker overall. The Nait should be able to drive both, although it depends on your desired volumes. The Squires will actually play louder (albeit not better).
-=> Mike Hanson <=-
1.no website at the moment.
2.If the room is not too big a Nait will drive them easily.The better the amplification the better they will sound.
3.I agree with Mike on this.
Greetings,Rob.
