Loading CD5 sounds odd
Posted by: Topof on 21 August 2003
Hi folks,
A couple of months ago my CD5 started making a strange noise when I loaded a disk.
My curiosity got the better of me tonight and I decided to take a look.
It seems to be the ribbon cable that attaches from the back of the transport assembly has somehow got itself into a position where as I push the transport into the machine it jumps up onto the circuit board (its quite hard to see in there).
Looking at a picture of a CD5 with the lid off it should have enough room in there without getting itself into that position.
I could leave it but any idea if this would cause signal degredation if its in direct contact with the board?
Prolly not worth a dealer visit - is it easy to whip the lid off the CD5 and would this void the warranty?
Dave
Posted on: 21 August 2003 by joe90
What you speak of can happen, but won't damage the machine in any way. Take it in to your dealer and get it fixed though. Not worth mucking it up.
Joe90
