DVD Recorders
Posted by: Laurie Saunders on 08 January 2004
I was considering replacing my VHS with a DVD recorder. I don`t really hire/buy films much.....mainly interested in recording off air.
My one concern is the reliability of DVDRW discs, having experienced one or two problems with CDRW with my PC...they seem as prone to "bugs" as the floppy discs I used to use.
I don`t want to spent a fortune, and would want to integrate it with my existing hi-fi.......may consider adding surround (rear) speakers at some point
Any advice/comments
Laurie S
Any advice/comments
Laurie S
Posted on: 08 January 2004 by David Stewart
Pop round to your local library (reference section) and grab a photocopy of the December 2003 WHICH? Magazine - there's a good review of DVD recorders in there. Panasonic seem to be favoured - friends of mine have bought them and been happy!
Posted on: 08 January 2004 by Former member
I know it's not quite what you were asking about but have you thought of getting Sky+? The recording interface is foolproof and it integrates with your hi-fi. I think the sound is Dolby 5.1. Of course it doesn't play DVDs.
The box is about £200. Plus you have to pay £10 per month if you don't subscribe to any of the premium channels.
Matt
Matt
Posted on: 08 January 2004 by Chris L
Admittedly it's been a while since I looked at domestic DVD recorders (a couple months, but that's quite a while in techno-world!), but I was very unimpressed with the ability of the DVD recorders to really replace videos.
Due to the restrictions on real-time encoding of the video stream direct to the disk, you couldn't get more than an hour of really good quality video.
Plus, reducing the quality to get more on the disk doesn't result in "nice" increased noise across the picture in the way that LP mode does on VHS, but you get awful, intrusive digital artifacts which really ruin the picture.
So I'd check very carefully before investing. And I'd, as suggested above, consider the time shifting boxes such as Sky+ or TiVo, or even (for the techno-literate) Personal Video Recorder (PVR) type software and hardware for your PC.
If the DVD recorders are now up to a standard to replace VHS, I'd be very interested to hear that.
Chris
Chris
Posted on: 08 January 2004 by Stephen Bennett
I've replaced my video with a Phillips DVDR70. The quality of the 4 hr mode is much better than VHS and useable at 6hr. The 2 hr is superb.
It also records and monitors in 5:1 so I can listen to cable and terrestrial in surround live through te DVDR, as well as listen during playback. Recording is as simple as video (or as complicated, depending on your view!) and it has videoplus.
You can play write once DVD+R on most other DVD players, but the DVD+RW, which is re-recordable, is a bit picky about what it plays back on. You can't just lend your friends DVDs you record like tape - but I just make copys on my computer and lend those instaed. Discs are about a quid each and I have 30 in the space about 10 Video tapes took up.
It was £250 from Comet in November.
Stephen
Stephen
Posted on: 08 January 2004 by Rasher
Whooa..Stephen...hang on.
Why can't you lend your mates DVD's to play if they are compatible with other DVD players?
Have you tried copying old VHS tapes to DVD with it?
This sounds very tempting.
I know there are some new machines that are DVDR & HD combined.
DVD+R can play on most other modern DVD players and computers. These are one off recordings though - not the usual method of replacing a video, right?
DVD+RW are re-writable, but can only be played on DVD+RW compatible computers and DVD+RW compatible players - ie not all of them!
You can indeed do Video to DVD copies.
I'm really happy with it.
Stephen
Bugger...that means I need to have one! Thanks Stephen.
Posted on: 09 January 2004 by David Stewart
I think it's worth waiting a bit longer for the machines with built-in HDs to come down in price. Unless you want to do a lot of longterm archival rather than time-shifting, they seem to make more sense and (according to WHICH?) have recording times of 8-14 hours in best-quality mode.
Posted on: 09 January 2004 by Rasher
I would normally agree David, but when widescreen TV's first appeared about 7 years ago, I bought one and waited for the transmitted broadcasts to catch up, channel 4 were 16:9, BBC were mainly 4:3. It was interesting. Then we considered plasma and after taliking to a mate, he told us that it was worth waiting until they were £2000 and had a contrast ratio of at least 700:1. So we waited for that, whereupon talk was beginning of LCD. Then LCD is now undergoing a new technology and it's worth waiting again until later in the year when prices will drop, screen sizes increase, and the quality gets better. Then with DVD recorderes....well, we could wait forever if we don't just plug in at some time. I have seen the Philips DVDR70 at Richer Sounds, multi region for £229. At least I can copy all those VHS tapes and get a few shelves back. If it's obselete in 18 months, then it's not the end of the world. £229 is cheap enough not to worry.
Posted on: 09 January 2004 by domfjbrown
I'm with Rasher on this - if it's REALLY that cheap at Richers, I'll wait until my summer bonus (if we get one!) and buy a machine then.
Got a lot of good movies and BBC2 stuff such as the Love Bites series that need backing up - oh, and Portishead's performance on the 1995 Mercury Music Prize...
__________________________
Make your choice, adventurous Stranger;
Strike the bell and bide the danger
Or wonder, till it drives you mad,
What would have followed if you had.
Posted on: 09 January 2004 by mctavishmacturbot
I went for the Toshiba RD-XS30 which has a 60GB hard disk and DVD-RAM/DVD-R drive. About 500 quid off the web. Very impressed so far - the dual drive makes it very flexible. You can record to HD and watch DVD which was good while i was copying all my old videos.
john
john
Posted on: 09 January 2004 by minime
i have a panny as well very nice and trouble free
a word of warning if you see a cheap philips 880-890 stay away most of them are bug ridden
Posted on: 10 January 2004 by HTK
Prices of HD players are being kept artificially high and are bound to come down a lot before too long. How much does an 80Gb HDD cost? So where's the rest of the money going?
Harry
Harry
Posted on: 10 January 2004 by Chris L
Hmm, well I'm humble enough to admit when I'm wrong - I think some further investigation may be in order.
Although, for me, it looks as though a digital tuner card and lots HDD space on my PC may be the better route for me.
Chris
Chris
Posted on: 12 January 2004 by Laurie Saunders
Thanks folks....my main concern is over the reliability of re-writable discs as a replacement for VHS tapes for time shifting.
With tapes, although the quality deteriorates, at least it is rare for them to become totally unreadable. My experience with CDRW has been unsettling
Laurie S
Laurie S
Posted on: 12 January 2004 by domfjbrown
Yes..it http://www.richersounds.com/index.php?f=itemdetl.php&p=301515
BLEEDING HECK!!! Well - if I wasn't in the process of buying a CD5...
Posted on: 12 January 2004 by Duncan Fullerton
Just my £0.02 worth, but how much stuff do you want to keep for posterity? If the bulk of what you want to do is time shifting then I think Sky+ is the way to go. If you want to archive stuff then you can always transcribe it to VHS or whatever.
Duncan
Duncan
