SNAXO On/Off Switch
Posted by: Thomas K on 13 November 2001
Why does the SNAXO have an on/off switch? Seems pointless as, like a pre-amp, it has to be powered from a separate PSU. I'm sure there must be a reason, though.
Thomas
Posted on: 13 November 2001 by Paul Stephenson
"I'm sure there must be a reason, though"
This allows connection and dis-connection without powering down.
Posted on: 13 November 2001 by Thomas K
OK, that makes sense. Cheers.
I've just connected mine to a SUPERCAP (replacing a HICAP) - the improvement is quite noticable, and I'm not even using a Burndy yet, only a normal SNAIC!
Thomas
"the Snaxo modified,to be silent when turned off.
I had a Naxo 2-4 before and it was buzzing throu the speakers when it was on,but quiet when turned off."
THe buzzing you had on the naxo2-4 should not have been there.
If you want the Snaxo silent turn the power supply off, the on/off on the snaxo is to enable change without powering down. THe buzz you have when in "stand by" is normal the unit is only intended to be in this mode for a few minutes.
