Active or passive??
Posted by: Charlezz on 05 January 2002
I entend to buy new loudspeakers in order to wait before I can buy NBL; But I have got a question:
Which is better between:
-CDX/Nac102/Supercap/Nap135/passive SBL
and
-CDX/Nac102/Supercap/2*Nap250/Snaxo/Hicap/Active SBL.
THanks
Charles
Try adding the XPS to the CDX or moving to the CDS2. Either combination will sound better through what you have now into SBLs than the bare CDX into active SBLs, which are FAR too revealing for a CDX (as good as that player is).
Bob
What is the best between :
cdsII/XPS/Nac52/Scap/Nap135/Passive SBL
cdsII/XPS.Nac52/Scap/2*Nap250/Snaxo2-4/Hicap/Active SBL
Charles
I think the difference between those two systems is one of preference. I personally greatly prefer SBLs active with 250s to passive with 135s, as does, I believe, Ken C (Ken--keep me honest here!). Active to me plays tunes better and sounds better then passive with 135s. However, a 500 passive is even better, and easily betters SBLs active even with SNAXO/Scap/4x135s.
I've owned active SBLs with 250s and prefer them still to passive with 135s. You pay your money and you take your choice!
Bob
But, anyway, as you told me, going active is not my next upgrade!!!
But i really need better loudspeakers than mines; and i would like to choose a pair of speakers that would be an intermediary step before Active NBL.
Which speakers do you think i should choose?
ps: i think s/h is generally a good way of buying loudspeakers.
Charles
A Supercap on the Snaxo is reckoned to blow your skirt up and expose your knickers. It's my next move.
I'm keeping the curtains closed!
After upgrading the front end I look forward to the SNAXO w/SuperCap (only not the cost of it
-John
But i really need better loudspeakers than mines:( ; and i would like to choose a pair of speakers that would be an intermediary step before Active NBL.
Thanks in advance.
Charles
My vote would be for used SBLs with the newer cabinets--the ones that are veneered on all sides. (They will automatically have the newer drivers, unless someone replaced the newer drivers with older ones for some unknown reason.)
They should sound great with your system now and let you hear all the upstream upgrades it sounds like you'll be undertaking. They also look nice according to my wife (we have a pair in cherry). The NBL also represents a logical step up--you won't have any culture shock shifting to NBLs from SBLs (other then how much better NBLs are).
Bob
Could you send me a picture of yours??
Charles
Mario
The older cabinets are painted black on the tops and bottoms of each unit so that if you look between say the bottom and bass bin you can see black. The new cabinets are veneered all the way so that if you look between you will see wood. As I remember the older SBL grilles seemed to not fit as well as the new ones, I may have just seen a few dodgy grilles though.
Can't help with the speakers, presumably if they are in older cabinets you should find out if they have been upgraded because by definition they will be the older type otherwise
you are correct bob, when i demoed at grahams this time last year, i preferred the active setup by far. fwiw, my nephew, will, prefers the passive 135's (and he's recently bought a pair) -- so, as is always the case, its down to personal preferences.
enjoy
ken
