Michell Tendercups
Posted by: Jack911 on 13 January 2004
Does anyone know where I can buy Michell Tendercups in the UK, preferably online?
Posted on: 13 January 2004 by i am simon 2
http://www.audiophilecandy.com/prodet.asp?pcode=I-MIC-TFSM&rel2=I-MIC&0=More+Info
the cups are there somwhere as well
Simon
PS i have some of each and they seem great value
Posted on: 13 January 2004 by Jack911
I just checked with Michell and apparently the Tendercups have now been discontinued.
Posted on: 14 January 2004 by NaimThatTune
Chaps,
I was saddened by the demise of the Tendercups too (well maybe that's a bit strong but I mumbled under my breath and went in search of a alternative). Seems odd, as the cups are only Tenderfeet with a dimple machined out of the top.
You can get RDC cups, also from Audiophile Candy. To my delight these are a lot harder than I expected - I was expecting something 'squishy' like a tap washer or lump of cork, but these things are like hard plastic and can bear a lot of weight. I can't get one to deform at all no matter how much force I put on it by hand.
The price is about £18 for four.
They fit Michell Tendercups very well - some pictures to follow shortly.
Richard.
The cups are 30mm diameter, by about 8mm tall.
They fit Michell Tenderfeet quite well.
