I know its not exactly hi-fi, but for those of you who work with computers and enjoy the radio on, if you use the following you can get a Psion Wavefinder for £39. It attaches directly to your PC and you can encode straight to mp3 from it...makes getting your fave songs easy I guess!!!
Go to
http://www.psion.com/storeClick on the Wavefinder picture,
Click on Order Now
Click on Check Out.
On the next page enter coupon code DIGITAL1WAVE
The price will be discounted to £39.44 (including VAT and shipping)
The offer expires on Fri 26 April.
Scott
Posted on: 22 April 2002 by markcas
Just ordered one for my Dads birthday. He's a bit of a gaget man so he will be happy.
Mark.
Posted on: 22 April 2002 by Scott Mckenzie
Mark.
For further info, apparantly the software from
here is a lot better than the standard bundled stuff too....
Posted on: 23 April 2002 by John Channing
I bought one of these using this offer a couple of weeks ago. As a Windows XP Home user I had loads of trouble trying to get it to work. This was not the fault of the Wavefinder, but is a problem with the USB drivers supplied with XP. With these drivers you get constant problems with the sound looping and skipping a bit like a scratched record. The solution is to overwrite the XP USB drivers with the ones from Win2K. This is not difficult provided you are a reasonably experienced computer user and you are able to follow a simple set of instructions precisely. The instructions and USB drivers can be found at
Windab. I also consider this to be a better player than Dabbar.
Once you have this lot working it is defintely worth all the effort. I spent about 4 hours last night listening to radio whilst surfing the net or filling in a spreadsheet without and further troubles.
John
Posted on: 08 May 2002 by garyi
Of course you could just get a lead to go from your sound out port straight back in your sound in port then record via say Audion, or Winamp which will happily convert to mp3.
That will cost you around 2 quid.
Don't believe the hype folks.
Posted on: 11 May 2002 by Scott Mckenzie
Originally posted by ged:
I am getting skipping of sound, sometimes it plays fine, other times it skips - regardless of software - windab, dab bar, or psion software, anyone got any ideas, I have installed the latest version of the psion software and updated the java software to the latest versions, can anyone offer any advise its driving me mad, the signal seems to be ok, 5 green lights in the psion software, however this seems to drop off when the sound is skipping
Ged
I haven't installed mine yet...it only arrived 2 days ok, so I'll do so and let you know if I ahve any problems. Might be worth emailing Psion directly, are you on the edge of an area which receives DAB as you could be losing the signal??
