DVD Remote broken?
Posted by: Graham Ridgway on 06 May 2007
My DVD5 remote seems to be broke. It controls the AV2 ok, but not the DVD. I know it is the remote as it behaves the same on another DVD5/AV2 setup, and the remote for that setup works ok on mine.
Any diagnostics, resets or other ideas other than get a new one?
Graham
PS Yes, I did change the batts!
Posted on: 06 May 2007 by David Dever
See FAQ
Posted on: 07 May 2007 by Graham Ridgway
awesome, the power of the wibbly wobbly web...it works. Thanks very much.
Graham
