Wish list for the n-Serve application
Posted by: Jan-Erik Nordoen on 12 October 2010
Seeing that Christmas isn't that far away, here's my wish list for consideration by the Naim elves currently updating the n-Serve app :
1/ A higher definition version for the iPad (presumably under development)
2/ Ability to access playlists created on the Serve
3/ Ability to edit names of composers to surname then first name (currently only sortable by first name, this is really not practical for classical music where the rest of the world goes by surname first... and Johann was a popular name in past centuries!)
4/ Cover-flow, as in iTunes and others
5/ Higher resolution images of album covers (iTunes does this better)
6/ Inclusion of links to PDF files of CD booklets, when these are available (see for example the Analekta website)
I'm sure others will have things to add.
Thank you all for your consideration and your good work and hope to hear from you soon
Jan
Jan
