Linn brings Radio DS
Posted by: Klout10 on 25 May 2010
Good news for Linn DS owners: a software update for all DS products makes internet radio possible.
I wonder if - and when! - this will become available for the HDX and HDX SSD!
Any thoughts?
Michel
Posted on: 25 May 2010 by 0rangutan
You can listen to these from http://radio.linnrecords.com
I have tried adding these to the Uniti Vtuner site (naim.vtuner.com) but no success. Anyone got this working on a Uniti?
Thanks,
John
Posted on: 25 May 2010 by DarrellK
I added these to my squeezebox, they work fine.
Linn Radio http://89.16.185.174:8003/stream
Linn Jazz http://89.16.185.174:8000/stream
Linn Classical http://89.16.185.174:8004/stream
Posted on: 25 May 2010 by adca
Thank you. Just save me a bit of work and time.
Posted on: 26 May 2010 by 0rangutan
Thanks Darrell - I eventually worked this out too by opening the pls files in notepad.
They now work well on the Uniti using the correct URLs.
Thanks,
John
Posted on: 26 May 2010 by JYOW
Way cool!
320Kbps stream with no interruption even to Hong Kong.
Beats pathetic DAB
Posted on: 26 May 2010 by pcstockton
Are these UK only? I cannot get hem to stream here.
Posted on: 26 May 2010 by Aleg
No, I'm outside of the UK and they stream just fine.
What are you using? I just add them as a location to my playlist in Foobar and away they go.
aleg
Aleg,
I am not up to speed on streaming radio. I simply clicked on the link, then the Quicktime logo showed for a few seconds. Then a Quicktime "mimi player" window opened. Then nothing.
I will try through Foobar.
Thanks!
-patrick
