HDCD - what's that all about then?
Posted by: Tony L on 21 September 2001
Ok, what is HDCD, and is it actually better?
As someone who owns over 1000 CDs, and whilst I have obviously only played a fraction of that amount on my CDX yet, the fact that I have only noticed one HDCD surprises me (the CDX displays 'HDCD' in the display for a few seconds when you play one). This being the case, and assuming that it is superior, it does not look that good for any future CD compatible technology being seriously taken up by record labels as this one looks like it has largely been ignored.
Comments?
Tony.
Mark Knopfler is a big fan.
It's always a nice day for it, have a good one ![]()
Steve
Can you have it removed?
Tony.
Tony,
No. HDCD actually clogs up your system's dynamics over time and you need to play a Mark Knopfler CD to get rid of this nasty side effect. Bummer, ey, but luckily you can leave the house when you put the MK disc on.
Thomas
Bummer. At least the Densen De-Magic CD sounds pretty cool in a kind of post electronica clicks and cuts kind of way...
Found out that my 7CD Doors box set should be HDCD according to the www.hdcd.com site. Will give it a spin tonight.
Tony.
Apparently HDCD is something vaguely similar to what Dolby noise reduction did, except that it’s not meant to reduce hiss, of course, but to inject (or retain?) dynamics. I met a guy once who does some mastering work for Linn, and he had some misgivings about HDCD (unfortunately we didn’t have the time to discuss it further).
In any case, I have about 10, and the recording/mastering quality is usually quite good. I suppose that may be because anyone who’s willing to dish out the licensing fee cares about the sonics enough to closely monitor the entire recording process.
Thomas
I doubt, however, that you'll find any Boyd Rice re-mastered in glowing HDCD, though.
Dave Dever, NANA
From the 460 CD's in my collection I only found 2 till now.
Chris Isaak - "Baja sessions"
and John Lee Hooker - "Don't look back"
Well,we'll see what it does on my s/h (only 1 year old) CDX which will be arriving in....about two hours from now
Greetings,
Alco
Thomas
HDCD encoded discs I have include most of Joni Mitchell's back catalogue, Paul Simon's "You're the one" , some of the more recent Emmylou Harris (Wrecking Ball at least) and one of Dire Straits.
I have an impression of a reduction in noise but I feel that this may be at the expense of some loss of tightness in the Bass. Unless all discs were HDCD and the system then set up around it's characteristics, it may be impossible to reach a conclusion. What I can say is that it dos not make CD superior to Vinyl.
It's also something which Naim do not themselves promote. It just happens to be included with the processors (or whatever) they use, apparently.
I've run the whole gamut on this one before.
BTW Tony - The Doors box set sounds bloody awfull!! Stick to the vinyl.
Pete. - NIMDA free. Now.
Apparently the Nick Drake re-issues were experimentally mastered in both HDCD and noise-shaped 24 bit. Joe compared the two and greatly preferred the 24 bit.
HDCD: analog-to-digital transfer through the Pacific Microsonics encoder box (first pass) at 24-bit (88.2 kHz, 44.1 kHz or higher multiple thereof), then a successive encoding (AES-EBU digital in) to 16-bit/44.1 kHz, where the two least-significant data bits are used for a "companding" process (extrapolated to 20-bit 44.1 kHz information on playback).
Example: Joni Mitchell re-issues
24-bit: analog-to-digital transfer through convertor of choice (dCS, Apogee, et. al) at 24-bit/44.1 kHz, noise-shaped to 16-bit data by onboard DSP at the convertor, or "off-line", that is, during DAW editing.
Example: David Bowie re-issues (recent Abbey Road-mastered set, not the Toby Mountain / Rykodisc re-issues)
Dave Dever, NANA
There are a couple of professional discs (from Classic records) where they have the same track mastered on HDCD, then Apogee UV-22 and then XRCD. From what I haved heard the latter two better HDCD and there is not much difference between XRCD and Apogee. Having said that, the HDCD encoder (not decoder) has been improved since then and this is what has been used for Paul Simon's latest, but not I beleive the slightly lifeless Joni Mitchell and DOORS re-masters.
Ah the Bowie re-re-re-releases. One sounds terrible, the other merely crap.
Anyone know what the Tom Waits re-mastering is being performaned on?
Dave Dever, NANA
