Accessories for LP's
Posted by: Action on 04 February 2004
Hi All
I've run out of inner and outer sleeves,I would like your opinions on what are the best ones out there .I currently use Nagoaka inners but find them a bit fiddly and floppy>
Thx
Mike
Thx
Mike
Posted on: 04 February 2004 by Richard S
Try Covers 33 in Halifax. Mail order specialists.
The outer PVC and inner lined paper bags can be highly recommended.
covers 33
regards
Richard S
covers 33
regards
Richard S
Posted on: 05 February 2004 by greeny
Action
If you're from Gee Cross nr Hyde South Manchester then you might want to try Piccadilly Records in Manchester who sell inner sleeves (with the paper and pvc) for 12p each I think. Last time I looked at the Nagaoka ones they worked at about double this price.
They also sell outer sleeves though I've never bought any of these.
Or you could try the Northern HiFi Show this weekend at the Radisson SAS Machester Airport. There's a chance some suppliers might be selling this type of stuff.
Posted on: 05 February 2004 by Richard Dane
If you find the the Nagaoka inners a bit tricky to handle then I would strongly recommend the Discwasher inners. These are the type used, I believe, by Mobile Fidelity for many years and I've been using them myself successfully for almost 20 years. I'm not sure whether they are still made new but I've noticed that batches of them appear for sale on the internet from time to time so if you spot any, snap them up!
Otherwise, the Goldring inners are a good low-cost option although they are best for cases where complete replacement of the inner sleeve is desired as they won't fit neatly inside existing inners.
Richard
Richard
Posted on: 05 February 2004 by Action
Cheers All
I'll have alook round the show on sunday and keep my eye on ebay.
Thx
Mike
Thx
Mike
