Newbie help with a Nait 3 and NAP 140
Posted by: mystik on 14 January 2003
I am looking to buy a NAP 140 power amp to add to my Nait 3. Do I need to do anything to my Nait 3 to get it running? Do I need the same version as mine (ie front green lit logo recent style)
Thanks alot.
Posted on: 14 January 2003 by Terence Chong
You'll need to convert the Nait 3 to become a preamp first. Bring this to your dealer so he can perform the necessary mods.
The mod include disengaging the pre-pwr section altogether, and adding a pre-out din socket.
When this is done, you can connect the Nait 3 to the NAP 140 via a din cable...
I think the old and the new versions are compatible. Give it a try though, if you can get them both.
All opinions are solely my own and not forceful in any nature.
Posted on: 14 January 2003 by Phil Barry
While the Nait can be rewired to serve as a preamp, it is likely to be financially beneficial to sell the ait and buy a used 62/92.
A 62/92-140 is a great combo. You might even be able to trade the Nait for a 62/SNAPS....
Regards.
Phil
Posted on: 15 January 2003 by Constantin
I made the same thing with mine and added an old style NAP 140 and after some time a HiCap.
It really does worth every penny in sonic improvement. But the moddification must be made by your local/nearest Naim distributor. Recently I homemade my own Fraim which considerably improved the whole sound.
Friendly yours,
Constantin
Posted on: 15 January 2003 by Steve C 01
I converted my Nait3 to a 92 to work with a 140.
But when upgrading I also had to convert it back to a Nait3 again to sell it quickly and at decent price.
Sell the Nait3, buy a 92, 32.5 or 72, it's quicker and cheaper, and if you go for the latter options, better sounding too.
Steve C 01
