N-Vi front panel display problem...
Posted by: james n on 27 October 2007
Popped into my local dealer today to enquire about updates and checked out their n-Vi model in the showroom as i was curious if the display is still working properly on mine.
Although mine looks on first glance ok, I have what looks like slightly darker vertical strips across the display - most noticeable on the horizontal power up bar, but visible when a lot of info is displayed (ie playing a DVD), so it'll be off to the dealer next weekend for a trip to Salisbury.
Anyone else had this ?
James
Posted on: 29 October 2007 by Margan
Yes, I have. Still hoping (with little hope) it might be a firmware issue...
Posted on: 29 October 2007 by StephenN
Same on mine, I just ignore it. Is it important?
Posted on: 29 October 2007 by james n
Not really - but if the display is on its way out then i want it fixed. It looks a bit naff too...
James
