PC unable to copy photos to CD.
Posted by: BigH47 on 17 May 2007
PC running XP home:-
Whilst trying to copy to CD our Nile trip photos, I did the normal "copy to CD" it goes through the usual temp copy etc when it starts to write,the Wizard says "an error occurred when writing to CD". The error message says the software is used under license from Roxio, no clue as to the programme name.I did the usual disk clean and ran PC Optimise.
If I use Nero I can make an ISO data CD OK.
Howard
Howard
Posted on: 17 May 2007 by Willy
Howard,
Firstly to save the usual suspects the bother..
"Go buy a Mac"
Now that that's out of the way..
"Go get some decent CD burning software"
Roxio software, in my experience, is totally unreliable. Would recommend CDburnerXP pro (http://www.cdburnerxp.se/). It very good and it's free. Has never let me down. If you like it then you can paypal them a few $s. That's only polite.
Willy.
"Go buy a Mac"
Willy.
Posted on: 17 May 2007 by Guido Fawkes
quote:Originally posted by Willy:
"Go buy a Mac"
Willy.
I thought we agreed that although the Mac is a better machine we weren't going keep telling PC users to buy a Mac
Posted on: 17 May 2007 by fatcat
Howard
You don't need CD burning software.
Go to my computer
Right click recorder drive
Click properties
Click on recording tab
Tick, ebable CD recording on this drive.
Select burn speed, Click OK
Insert blank disc in drive.
Go to my computer
Open recorder drive
Drag and drop or copy and paste photos into recorder drive
Click on “write these files to CD
The Mac is a very good machine, ideal for people who lack the intelligence to use a PC.
Go to my computer
Click properties
Go to my computer
Open recorder drive
Posted on: 17 May 2007 by garyi
Sounds like you have one of those time limited demos underway or something.
quote:Originally posted by fatcat:
The Mac is a very good machine, ideal for people who lack the intelligence to use a PC.![]()
Yep that's me.
And me, I have to put up with inserting a blank disk, dragging files onto the disk and ejecting it.
I do sometimes wish it was more complicated, I really do but I is thick.
quote:And me, I have to put up with inserting a blank disk, dragging files onto the disk and ejecting it.
You have to eject the disc after burning. That must be a bit of a ballache.
Posted on: 17 May 2007 by BigH47
I did find the error report on the MS site. It suggested much as fatcat said plus running services.msc and altering a setting for the drives to manual from auto. Needless to say that didn't fix it. Of course I missed the obvious work round and used a flash drive. As I said using Nero and making a data CD also seems to work it just takes a few more keystrokes.
Thanks for the responses.
Howard
Howard
Posted on: 18 May 2007 by zorba
"The Mac is a very good machine, ideal for people who lack the intelligence to use a PC."
I used to be lucky and only had to work 12 hours per day + weekends. Now I am up to 15-18 want to keep fit and atleast SEE my children, let the other half no that she has a partner and listen to music and watch a film.
Intelligence I have, as all, but no time to become a computer programer so I can use a computer. Mac or PC I wanna turn it on and wannit to work thats what I paid for.
Am I really living in this country called Great Britain?
Posted on: 18 May 2007 by Deane F
