NNP IR
Posted by: Ben Murphy on 27 January 2009
I noticed in the documentation that the NNP(s) have IR receivers in the front and a IR port in the back.
Does anybody know how your able to make use of this IR port and what control device to use?
Posted on: 27 January 2009 by QTT
What is the NNP?
Posted on: 27 January 2009 by Ben Murphy
naimnet room amplitfers
Posted on: 28 January 2009 by David Dever
Only the NNP01 has an IR receiver built-in–there is no Naim logo (in which the IR receiver resides) on the NNP02, therefore an external IR receiver is required (fed into the rear "remote in" socket).
Posted on: 29 January 2009 by Ben Murphy
thanks for the confirmation on what device has what configuration. I have the NNP01 so assumed the NNP02 has the same.
Do you know what remote control I need to use to access the IR receiver on the NNP01 to control volume / mute etc? (just the basics)
