Worthwhile cartridge tweak.
Posted by: jonni on 27 March 2003
just tried out a "tweak" I've been thinking about on my dynavector cartridge.
the signal from the cartridge has to get to the tonearm wire via for pins on the back that are colour coded.At such low levels the signal is harmed by bad connections.The tags on my wilson benesch arm are not the tightest fitting either.
I wondered what would happen if I prised off the colour coded tags that fit over the pins to identify them , leaving more metal contact surface exposed?
I wasn't expecting much but was quite amazed
at the increase in dynamics, solidity ,low level resolution and presence and bogie coming from the record.
I'm off for more listening
