how to connect stageline to 112/150/flatcap2
Posted by: Eric Tang on 07 October 2003
What is the cable connection (requirement) for stageline to NAC112/NAP150/FlatCap2?
Does StageLine come with any cable?
Thanks in advance.
Posted on: 07 October 2003 by rgame666
The correct cable comes with the Stageline.
Connect it to the AUX 2 socket for power and signal.
Posted on: 07 October 2003 by Eric Tang
Does it require two cables?
1. Stageline to FlatCap2
2. FlatCap2 to PreAmp
On my setup I have the FC2 powering the CD5 and 112. So the 112 supplies power to the Stageline through the AUX2 socket. This way only uses one cable and it is supplied with the Stageline.
If you are only powering the 112 from the FC2 I do not know how the FC2 and Stageline are connected.
Sorry
Posted on: 07 October 2003 by Richard Dane
The Stageline comes with a SNAIC5 as standard. This way you can connect it directly to the powered Auxiliary socket on either the Nait5 or one of the latest preamps.
If you are using it with a dedicated power supply then the SNAIC5 connects the Stageline to the PSU but you then need an additional 4-5pin DIN Interconnect to connect to the preamp.
Richard
Thanks rgame666 and Richard.
Is Stageline a good phono amp?
The din cable cost half the price of Stageline, just too much.
Anyone use Trichord Dino, Audio Alchemy phono amp before?
