Kinky Records
Posted by: garyi on 10 February 2002
Any one know how I could remove some rather alarming bends in some records I got this weekend, they don't appear to be affecting the arm or cart but it looks scary!
Posted on: 10 February 2002 by Former member
Try putting the records between two sheets of glass and placing them in the sun for a few hours, not much good this time of year I guess but OK in the summer. I have tried the same routine putting them in a LOW heat oven. It does work but much care needed!
John T.
Posted on: 11 February 2002 by Keith Mattox
John T.
May I re-stress the word LOW. A friend of mine lost a one-of-a-kind record by having the oven on something higher than "warm". Try the sun first; if that doesn't work, then use the oven.
If you have a gas oven, take note to see if the pilot light already has it warm enough. If not - use the lowest setting you can possibly get with the oven still on. Let it get up to temp before you put the LP-wich in - does it feel the right temp to you?
Keith.
Posted on: 11 February 2002 by garyi
Cheers guys,
I think the airing cupboard is in order here!
