UnitServe... how do I load Hi Rez files?
Posted by: Chris Bell on 05 November 2010
Title says it all... how do I upload my high resolution file from sites like hdtrack.com?
Posted on: 05 November 2010 by pcstockton
Are you asking if you can put files onto the Serve's internal drives? If so, I dont think you can do this.
Posted on: 05 November 2010 by Tog
Naim don't like you messing with the innards of the Serve unless you are using the ripper. You can set it to scan folders on network drives though.
Dave Dever knows a lot more about it.
Tog
Tog
Posted on: 05 November 2010 by rock100
Hi Chris
I have a small NAS drive just for Hi Rez files. I shared the directory the files are located on.
The UnitiServe should find the share automatically. You just have to enable it by going into Settings / Shares (If I remember correctly) on the Uniti
Have fun.....
Have fun.....
Posted on: 09 November 2010 by PureHifi
Chris, I purchased some hi-res WAV files from MA Recordings and as my nas share is promoted to a store I could not get it to show in the index of music....
As it was the same album as a STD def version I had, I copied the cddb info file from the STD album into the hi-res version of the same album and edited the track names, etc to suit and then rescanned the store...only then did the album index itself.
Hope that helps....
Hope that helps....
Posted on: 09 November 2010 by Aleg
Hope that helps....
IMO it is best to always reserve a part of your NAS as a share, even when you think you won't download music.
aleg
Posted on: 09 November 2010 by David Dever
No upload needed - simply share the folder (via Windows Sharing on the Mac, if that's what you're using) and the UnitiServe will then be capable of playing the files directly off the drive.
Posted on: 09 November 2010 by Develyn
You could also add the hi res files to a flash drive and plug it into the back of the serve.
