Can someone tell me which fuse is required in the XPS, and if there is a better rated version available?
Posted on: 10 September 2003 by Richard Dane
Hi Chris,
the fuse required for a 230V/50Hz XPS is a 2.5A T rated fuse. The fuse ratings on all our equipment is actually printed on the rear panel for easy reference.
Uprating of internal fuses is definitely to be avoided. The internal fuse is carefully rated to comply with safety regulations and deviating from the required specification could, in the event of a fault condition, result in damage, fire, or injury.
Richard
