Speakers
Posted by: Jack on 13 December 2001
The sound has now vastly improved and I am very pleased. I have a CD3.5/flatcap/NAC92/NAP90.3 and intend to continue to improve via additional purchases as funds permit !
However, I have a set of Mission 733 speakers which I purchased many years ago. Reading through some of the posting I suspect that the next upgrade may well be the speakers ?
Could anyone suggest speakers that I should consider listening to as alternatives please ? Budget will be approx. £1000 but I want to ensure that whatever I buy will be suitable if I decide to upgrade the pre/power amp in the future.
I will be connecting a turntable in the future probably a Rega but that is on hold at present.
Any suggestions greatly appreciated.
Jack
Neat Mystique
Linn Ninka
Royd RR1
mykel
If you've got a grand to spend I'd recommend that you consided Intros or 2nd hand Credos. Credos would benefit from a better power amp but buying them 2nd hand should leave you cash over for a used 110 or 140. I've used both with my Credos and either performs well.
Steve
I would highly recommend the Contour Range as a minimum, and for that price range look at the Contour 1.1 or if you live near Worcester (UK) Audio Excellence have some 1.3 mk II's for a 1000 pounds...INHO, the Contour 1.1's do everything that Credo's do, but with a bit more weight to the bass.
Take a look here for Contour 1.1 info. and here for 1.3 info.
Scott
Phil
Phil
Originally posted by Claus:s/h SBL's!
Claus
What's the minimum power-amp to use with SBL's?
Steve
When I asked Naim at the beginning of this year if the 140 I had at the time was suitable, they said it was the minimum they would recommend. The 250 I have bought since gives a fuller sound, unsurprisingly, but I bought my SBL's because of how good they sounded on the end of the 140.
Ade
I would guess in a larger room the 90 won't cut it, but you may find a great deal on SBLs and I would seriously consider getting them, then after that the poweramp, there seems to be more amps on the market than SBLs so if you want them grab em!
Originally posted by Scott Mckenzie:
I have always enjoyed the sound of Dynaudio on the end of Naim equipment, your system is 'similar' to mine, or at least similar to the system in which i have heard many Dyn speakers.I would highly recommend the Contour Range as a minimum, and for that price range look at the Contour 1.1 or if you live near Worcester (UK) Audio Excellence have some 1.3 mk II's for a 1000 pounds...INHO, the Contour 1.1's do everything that Credo's do, but with a bit more weight to the bass.
Take a look http://www.dynaudio.com/products/contour/11/con11.htm for Contour 1.1 info. and http://www.dynaudio.com/products/contour/13/con13.htm for 1.3 info.
Scott
Can a Contour 1.1 driven by a Nait?
Thanks.
The Zephyrs have now given way to SBLs but the Zephyrs looked nicer and didn't sound much worse IMHO. But then again, most forum members probably think I'm half deaf as I think my CDX sounds better on my old Sound Org table than it does on Mana.
Speakers are something that's actually quite fun to demo, as they often have immediately different characters, so you don't find yourself hunting for tiny nuances to evaluate purchases.
John
Scott"
Thanks.
It can, it is obviously more comfortable on the end of something like a 140, but in a smallish room (like mine) then it works fine...the 1.3 runs easier but I prefer the 1.1's myself.
Scott
Jack.
Try the less expensive Dynaudio range, or Intro IIs.
