Have it got a virus? (PC problem)
Posted by: Bruce Woodhouse on 31 October 2009
My Dell Windows Vista desktop is developing a problem. I've a feeling it is software (ie virus) rather than hardware but I'm not even sure about that. I know these problems are always difficult to sort out without masses of detail but before I brave the Dell support can anyone give me some thoughts about this fault?
When switched on the PC Bios alarm trills continously on the opening screen. If left it just jams, but if I press 'F2 for setup' it will give me the setup screen. If I exit that it will boot up fine but the Vista password page appears then occasionally jams or suddenly loses the password box. After a few attempts it works fine and once logged on the PC works perfectly.
I've run the supplied Dell diagnostics (both from windows and the Bios setup) also a full Norton anti-virus scan plus the Norton Systemworks Windows diagnostics and nothing is reported. The problem did not start after any new software or hardware installations.
Any thoughts on this? I have the Vista install disk and was wondering about doing a re-install. Everything is backed up.
Does this sound like a Vista problem? The Bios alarm made me think it was memory or similar but why then does it all run perfectly afterwards?
Bruce
Bruce
