Washing Machine
Posted by: HTK on 17 January 2006
Anyone know of a washing machine with a cold programme or manual heat setting that can go down to zero? They all seem to start at 30 degrees nowadays. Bit of a long shot but any info appreciated.
Harry
Harry
Posted on: 17 January 2006 by Spock
Harry
That won't get your undies clean!
Spock
Spock
Posted on: 17 January 2006 by long-time-dead
Zero. Would that not be an ice-maker ?
Posted on: 17 January 2006 by Bob McC
sorbet production on an industrial scale eh?
Posted on: 17 January 2006 by HTK
Ha ha ha, yeah, yeah, very good.
We won't *always* be washing cold.
I knew this was a bad idea.....
Posted on: 17 January 2006 by Stephen Tate
hi,
What about two rinse cycles - One to wash and the other to rinse.
Just an idea.
regards
Just an idea.
regards
Posted on: 17 January 2006 by u5227470736789439
This works quite well for things that must not be warmed up (delicate woolen things), though I find a good soapy cold soak overnight in the bath followed by the rinse cycle gets things properly clean.
I am a boil it till the colour drains away person myself!
Fredrik
Posted on: 17 January 2006 by Lapdog
Silly to ask you this but your machine has no cold setting?
Brian
Brian
Fredrik
Hi fredrik,
I made the mistake once of soaking a double quilt in the bath, although it was cleaned very well an d good as new, it turned out that i couldn't have a bath because i couldn't get the bloody thing out. It weighed an absolute ton!
I had to call on some old sea dogs to help me pull it out, those fishing net skills soon came in handy to say the least.(i had to reinforce the washing line)
My advice for today is - do not try this at home folks.
cheers, steve
Well that put a smile on my face! Fredrik
Posted on: 18 January 2006 by HTK
Brian
Yes it does. But I haven't seen a new one with a cold setting. Thus the question. Looks like they don't come so equipped any more.
Harry
Posted on: 18 January 2006 by Dougunn
Harry
I've got to ask . . . why?
FWIW I think the term 'cold' in washing parlance does not mean no heat it means under 30 degree or so. You can wash wool and other delicates at this temperature.
I don't think you will get clothes all that clean in completely unheated water; I'd guess that's why machines don't offer the option.
Doug
Doug
Posted on: 18 January 2006 by nicnaim
HTK,
Try Miele washing machines, they usually have a cold (i.e. mains temperature) setting on the woolens and delicates cycles. Expensive machines but an excellent long term investment. Built like tanks.
Nic
Nic
Posted on: 18 January 2006 by Stewart Platts
We have a Miele washing machine, model W3240 and it has one cold setting for woollens and another cold programme for delicates.
As nicnaim rightly says, Miele machines are built like tanks and this is backed up by the free 10 year parts and labour warranty that came with ours.
Yes, I too have a Miele - there is none better
But doesn't have a 'cold' (in the HTK sense) programme.
Although this might be the answer to your problem HTK as a Miele engineer can reprogramme the machine to give you an entirely unheated wash cycle if you wanted.
Doug
Doug
Posted on: 18 January 2006 by Tam
I have a Bosch Classixx 1000 Express (around £300 from John Lewis a few months back, and for £20 they installed it and took away the old one, but I digress), most of the programmes only go down to 30, but it does have a 'cold' setting for the woollens programme.
regards, Tam
regards, Tam
Thanks folks.
