Help - SBL's willy has fallen off!
Posted by: Steve Crouch on 13 January 2002
I have a late pair of SBL's driven actively by 135's and play at high volume setting. Last night I heard a buzzing from the right speaker. I removed the foam from the mid/bass to find the willy thingy had fallen off and was resting against the drive unit giving rise to the buzzing. I notice it was held on by double sided tape and I have simply pushed it back on for now. I guess it will work loose again so do I just ask Naim for some more tape or do I use glue?
Is this a common occurence and am I driving the SBL's too high (I normally have volume set at around 10 o'clock on CD.
Posted on: 13 January 2002 by Steve Crouch
Thanks DCM
Steve
Posted on: 13 January 2002 by J.N.
The moral is:-
Don't abuse your willy!
JN
Normally out of my control!!
Steve
