Group delay
Posted by: lemarchand on 10 January 2002
I am really sorry for my english but I am Greek ![]()
[This message was edited by lemarchand on FRIDAY 11 January 2002 at 03:53.]
Is that the question, I wonder?
Is that why most of us here seem go for simple two-way speakers, and eschew biwiring, bi-amping and active crossovers etc?
Next: sealed box versus ported versus transmission loading...
This tecchie stuff is picklin' me brain...
It's always a nice day for it
Have a good one! ![]()
Steve.
It's good to get back to normal. ![]()
Phase linear alignments (like bessel) gives "maximaly flat delay". The vast majority of speaker designer will favorize the best low frequency extension at the expense of weird group delay. This will give a speaker with low PRAT in the bass (sorry, you are a junior member, you have to make some research, use the search engine for PRAT).
The group delay due to accoustic tunning (alignment) is an order of magnitude superior to the group delay due to the crossover. As David says milliseconds vs microseconds.
An other factor of delay in speakers are the non vertical plane of speakers accoustic centers.
(except on slopped baffle). But very few specialists still believe in vertical alignment of speakers.
All this is very theorical, let the PHD's play with all these maths.
Chose your speakers by ear. And enjoy the music.
Emmanuel
lemarchand
I will therefore be interested to hear that sub of yours for subjective listening evaluation...
Will the bass extend below that of my Naos, and will overall PR&T be maintained?
Steve.
Well Manu, I choose speakers by ear from now and on, but having had a B&W ASW1000 subwoofer at the past I realised that it is easy to create the "tsiki tsiki boom boom" factor but the music will be wrecked big time. After some proper research mainly from the "Loudspeaker Design Cookbook" I decided to make my own subwoofer and try to make a "fast" subwoofer with decent output capability. My project will be done in one week time, I will give it one week to have a go and then I will let you know. A professional box designer has done the box design after I told him what my aim is. I will use a BK 200wrms sub-bass module amplifier with built-in active crossover and a JL Audio 10W0 driver.
Steve - "Will the bass extend below that of my Naos, and will overall PR&T be maintained?"
Well, that would be nice if it could happen.
As we have discussed at the past in my opinion Rega makes speakers with minimum group delay in mind, so it would be a difficult task for me ![]()
frederick charles - Thank you very much. When I refer to group delay I always have low frequencies in mind. The group delay is determined by the type of the box design, its construction maybe, the box's size and possibly by how the specific driver behaves within the certain type of enclosure. What I don't know is if the addition of the crossover adds group delay or not. Theory such as "big drivers are slow and small drivers are fast" is non-sense. The bigger drivers usually require bigger enclosures. If you stick the wrong driver in the wrong enclosure then yes the bass will be crap. Sorry, I have never heard of the Sara 9 speakers. If you want some more info about the above issues you could always purchase the above book I mentioned and have it a go.Cheers.
"The loudspeaker design cookbook" by Vance Dickison, Audio Amateur press, Peterborough, New Hampshire.
Steve.
[This message was edited by Steven Toy on FRIDAY 11 January 2002 at 17:09.]
Do you know the meaning of your french name?
Good luck for your project.
Some advices:
Don't know this driver. IMHO a paper cone is better for speed. Stiffer and lighter than polypropylen, never try Kevlar but should worth a try.
Use a software to calculate all parameters, i would recommand LSPCAD (a light version was available for free some time ago).
If you can, make all mesurements of the speaker parameters on the driver you get; there are big variations of them from unit to unit.
The "Loudspeaker design handbook" is a kind of bible, follow the advices. Also have a look at the "Loudspeaker design cookbook" by the same author.
Take very good care of the impulse response of your design.
Don't try to go down to 20 Hz with a 10", concentrate on good sound down to 30/35.
As your sub will be amplified, don't bother with efficiency, concentrate on good impulse response.
Closed boxes sounds better.
Spend time to try various stuffing materials. Rubberised dampers used for cars give good results but vapors they produce burn speakers.
Double veneered (outside and inside the box) panels are good for vibration control.
Natural wool gives good results.
And don't hurry, try, listen, retry....
Emmanuel
I already told him.
It means "shopkeeper" no less! ![]()
As for the loudspeaker cookbook, I have his copy, but the sub he's built is nearly ready anyway...
Je suppose que t'es canadien qui parle le francais en premiere langue. ![]()
Steve.
Oui, cela ce voit tellement dans ma "litterature"?.
In fact I'm a "french man in Montreal".
Lemarchand,
Can't agree with your comments about car speakers.
Most of the car speakers are cheap. Made to work with a big air volume, low sensitivity, 4 ohms.
Home/pro speakers are more advanced if you look at scandinavian, british, french, american (for Pro) companies.
Paper cones are good if treated with carbon fibers, making them stiff. Their break-up point is higher than plastic ones.
Is the inside port just a cylinder inside the box or a real port between 2 closed cavities. If it's the second option it looks like Naim speakers (SBL, NBL, DBL).
Tell us informed of the progress
Emmanuel
Steven,
Non, pas trop! ![]()
Steve.
Bear in mind I am speaking about low frequency drivers here Manu only. The box is a dual chamber one with a port between them, so it is "Naim style". I am more confident now
. Cheers
Serious basket.
Emmanuel
