would you exchange a cd5 for a CDX?
Posted by: Tennispro on 24 April 2003
Hi everyone out there. I am pondering upgrades and one way to upgrade my AV2 is to get a 202 for a pre and sell my cd5 w/hicap and get a CDX. Would the CDX be a big upgrade to the CD5 w/hicap. I would probably keep the hicap and put it on the 202! Thanks for any direction you can give me!!
Tennispro
Tennispro
Posted on: 24 April 2003 by Mick P
Think of the CDX as a Jaguar Saloon and the CD5 as a pickup. Yes it is much better.
Mick
Mick
Posted on: 24 April 2003 by rch
Tennispro,
yes, it WOULD be a big upgrade. Exactly like a CD2 would be.
Christian
Christian
Posted on: 24 April 2003 by herm
CD5: a very nice sedan, especially if you add a Hi-Cap
CDX: a 500 Mercedes
CDSII: Jaguar
And if you're looking for pickup: that's the CD3
Herman
Posted on: 24 April 2003 by achandoke
You think a jag is better than an E500 or S500 Benz? I think the E500 is one badass car. NO doubts about it. The Jag XJ8 is one sweet ride though, and if you mean the CDSII was one of those, I will agree
Posted on: 24 April 2003 by Steve Toy
I had a CD5/Flatcap2.
I also heard a CD5/Hi-cap.
I didn't sell the FC2 and buy a Hi-cap, I sold the lot and bought a CDX --- once I'd sorted my equipment suports.
The CDX reads what it sits on more so than the CD5, but get the support right, and the difference is massive in every area - dynamics, detail, timing, tune, soundstaging etc.
Steve.
Steve.
Posted on: 24 April 2003 by redeye
Steven...so what do you choose to sit your CDX on?
You know the answer to that question!
QS Ref, but there are other decent stands out there
Steve.
Steve.
No, I didn't actually thats why I asked.
Simple really..
Simple really..
Posted on: 24 April 2003 by Name
Jeez red even I could have told you that....
Posted on: 25 April 2003 by Matthew T
Tennispro,
Are you using the AV2 as your current preamp.
Going from CD5/Hi/AV2 to CDX/202/Hi/AV2 will be significant.
The CDX is a significantly better player then the CD5/FC2, haven't heard with HC. It sounds like your system is about to get a whole let better!
Decent support is strong advised with CDX.
cheers
Matthew
cheers
Matthew
PS Make sure you listen to 202 with digital supply NAPSC as this makes quite some difference (at least it does with the 102).
Posted on: 25 April 2003 by Tennispro
Is there a big difference between the CDX and the CDX2? Do you guys think that it would be worth shelling out twice as much money (2,000.00 to 4,000.00) for a CDX2?
Tennispro
Tennispro
Haven't heard the CDX2 but I would doubt the difference is that large, for the price of a new CDX2 you are ooking at a CDX with and XPS, I doubt the CDX2 is that good, I could be wrong!
Matthew
Matthew
Posted on: 25 April 2003 by Bob Shedlock
Roger, Since you're seeking opinions on CD players, look at stereophile.com, in the archives section to see what Fremer, who actually has listened to both players, wrote about the CDX v the CD5.
BTW, the presentation differences between the olive style and the new series is significant.
