iTouch control of HDX ?
Posted by: Roy Donaldson on 12 July 2008
Just seen this application which suggests control of Netstreams on the iTouch / iPhone and wondered if it would therefore work on the HDX as well:
http://www.automatedhome.co.uk/New-Products/iLoveContro...tron-NetStreams.html
Posted on: 12 July 2008 by james n
Allen - try the new remote app - very neat (free too !)
James
Posted on: 12 July 2008 by David Dever
If using a wireless touch panel with the HDX player's UI, the panel's browser must support Adobe Flash Player–at present, there is significant teeth-grinding between Adobe and Apple as to whether this will ever be available for the iPhone / iPod touch.
Anything is possible, however....
FWIW, I use a Nokia N800 (Linux-based, running 2008 firmware) to control the NS01 I am using at home (under Mozilla / Flash Player for Linux, installed by default). Older firmware versions utilized Opera as the browser.
I have tried the iPhone remote applet for iTunes control and found it quite usable, though I don't use iTunes that much beyond loading my iPod / iPhone.
Posted on: 13 July 2008 by garyi
Surely dave if the netstreams is the 'backroom' application and the naim interface the shop window, can't an application simply by pass the shop window?
For instance I have an appleTV which as the name implies you look at on the tv, however apple have just released remote control which allows me to control the music in itunes to play out of the appletv, meaning I don't need the TV on.
(A combination of ipod touch and appleTV is awesome BTW)
