Step by step upgrade
Posted by: louis_lx on 28 October 2001
What´s the better way ? to test betters et of components or do a step by step upgrade ?
In my case I have CD3 + 72 + 140 + REGA XEL
Target system (too expensive) will be CDX + 102 + NAPS + 250 + REGA XEL
How to do a step by step ?
Posted on: 28 October 2001 by Mike Sae
If it were my money, I'd do:
1.CDX
2.Hicap
3.102+NAPS
4.180
Why do you feel the need for a 250? If it were me i'd do a 180 instead and get a Hicap. As you probably know, the Hicap transforms a 72/140 and will make the time between 1 and 2 a lot less "painful"
*Addendum- as James pointed out, a 250 won't power a 102, hence the editing red face
Nevertheless, a Hicap on the 72 may very well alleviate the need to upgrade to a 102.
[This message was edited by Mike Sae on MONDAY 29 October 2001 at 01:28.]
Posted on: 28 October 2001 by Phil Barry
Are you planning on buying new or used? If new, you can dramatically increase your options by going with used equipment instead.
Also, what's your patience level? If you're impatient, get a hicap ASAP.
Phil
