co-ax runs
Posted by: kenngxx on 24 August 2006
I,m moving my av set up ,and the spot where its going has a co-ax wall socket connected (invisibly? to the loft space.
TO connect another cable( for sky+ or an aerial )is going to be difficult and not very neat due to the position.
Does anyone know of any way of sending two signals down the one coax.either a sky and aerial, or two sky signals for sky+ ,so I can watch one channel and record another one?
at present I only use sky for all channels and have no aerial.
Thanks in advance
Posted on: 25 August 2006 by Stuart M
Yes something like this will multiplex the signals into one coax. You then use a demultiplexer at the other end. It also lets you view SKY (or any other compatable box) and control it by remote in another room.
http://www.letsautomate.com/10567.cfm?
Posted on: 25 August 2006 by kenngxx
Thanks Stuart.
Didn't know such a thing existed.
I'll now try to figure out how to do it!
Kenn
Posted on: 27 August 2006 by David Sutton
Hi stuart,
Can I use this same method to distribute my NTL cable TV throughout my london home??
Looks great!
Posted on: 27 August 2006 by Stuart M
If the NTL box outputs an RF signal yes it should work.
If you want to send the TV distribution you could use something like this to combine the feed with a standard TV signal and distribute that.
If the NTL box only outputs a composite/RGB/Svideo signal then you could use an RF modulator to distribute it.
More info here http://www.satcure.co.uk/accs/rfmod.htm
I doubt if the remote control would work but there are solutions out there for that if you needed it.
Posted on: 30 August 2006 by David Sutton
Thanks Stuart!!
Posted on: 11 September 2006 by kenngxx
I,ve since found this also
http://www.parabolic.co.uk/catalog/product_reviews_info...id=193&reviews_id=29
which is for use with 2 lnb,s ie Sky plus
Kenn
Posted on: 12 September 2006 by jasons
Kenn
As per the OP you will need Sky Plus box if you wish to record one channel on Sky and watch another on Sky.
