Help! Problem with DVD connection to old telly
Posted by: syd on 02 February 2004
Hi All I hope you can help me with my problem. I bought a cheapo ALBA DVD45 player for £29.99 to connect to my very aged Sony TV. The outputs on the DVD are either Composite or Scart but the input on TV is standard RF coaxial aerial socket only. So I've connected it via my Pace Telewest box using a Scart Cable. I have had no problem playing the Telewest Cable through my TV on its RF output but I can't get anything on screen when trying to set up TV for the DVD. Is it a possible faulty DVD player or is the TV not compatible with DVD playback. The Composite outputs may be OK but as neither the TV nor the Cable box have inputs for this I can't tell. I have tried a couple of Scart cables in case it was this as the Telewest box came with two. I used to rent a 32" Sony with all the connectors but gave it up recently as I was watching very little TV.
Your'e help would be much appreciated. Thanks in advance.
Yours in Music
Syd
Yours in Music
Syd
