N-vi
Posted by: Ray Thompson on 10 January 2006
Does anyone know when the n-vi will be avaliable at Naim stockists,I rang music matters my local naim dealer and they have been waiting since december for stock?
Anyone
Anyone
Posted on: 10 January 2006 by Frank Abela
I think we're looking at February before it becomes available in most dealers. From what I've heard when I played with it last month, it's worth waiting for.
Posted on: 11 January 2006 by Tuan
For home theatre, would it be better to use active speakers (self-powered) from Bang-Olufsen or Meridian? Somehow I still believe that the sound is more "punchy" if active system is used. I am not sure on this issue and I am in the process of making a mini home theater in my room, starting with the SONY KDL-V40XBR1 LCD 40 inch display and a SONY DVD upscaling/HDIM connection player.
Posted on: 11 January 2006 by David Dever
...depends on whether sound quality is an issue: many active loudspeaker manufacturers are using similar switching amplification (as used in the n-Vi) as amp modules; however, as the sound tends to be dependent on the quality of the power supply, they often fall short by a large margin due to the space constraints within the cabinets.
Bang olufsen, Linn, Meridian are champions in using switch-mode power supplies and now Naim follows this path. Would it be safe to say that the technology is now mature and the sound quality is there? How "good" is Linn amplification, those beautifully made high-end Linn amplifers.
Posted on: 11 January 2006 by Frank Abela
Tuan,
Naim have stated clearly that the switched mode power supply was used only because of space constraints. The same goes for the Class T power amps in the n-Vi. To suggest that Naim are following the path is a little premature I think.
I have listened to the Linn stuff and it certainly isn't my bag. Beautifully made though, I agree...
Posted on: 11 January 2006 by kuma
Frank & Dave,
Have you heard the n-vi?
Does it still sound like Naim?
Tuan-
You missed the point. A switching amplifier (digital amplifier, class D, class T) is NOT the same concept as a switching power supply. Often, the differences between two manufacturers using the SAME switching amp modules can be traced to differences in the power supply designs (of either type, linear or switching).
Kuma-
Yes, still sounds like Naim (even on Harbeth HL-P3-2s, to boot, which is what we had on static display in the lobby at T.H.E. Show).
Kuma-
David,
That's interesting.
So there is a hope for the Tripath yet.
I used to own a Tripath chip based Bel Canto amplifier. ( for a home cinema )
Recently, I believe they switched to the ICE module which I understand because of the cost.
That's interesting.
Posted on: 12 January 2006 by Frank Abela
Kuma
I haven't done a direct A/B of the n-Vi against, say, a DVD5/AV2/150x or CD5x/112x/150x, but what I heard certainly sounded like it had some of the Naim PR&T, and was certainly more engaging than most HT systems I've heard.
Posted on: 18 January 2006 by Margan
Kuma,
I had a direct A/B (with CD) of the n-Vi at my local dealer against my CD3/NAC92/NAP90.3.
It really sounds like Naim and is definitely better than my old combo. So I sold my components and bought an n-Vi. Great!
I haven't heard it but my dealer told me the n-Vi CD sound is much better than the CD5i and comes close to the 5x.
Now I'm looking forward to a video connection with my beamer...
Posted on: 06 February 2006 by Robbert
quote:Originally posted by Margan:
Kuma,
Is there a posebilety of adding a powersupply to it? I have a FC2 to ad.
And is it posible to play stereo?
Posted on: 06 February 2006 by David Dever
quote:And is it posible to play stereo?
Absolutely–and at this it does remarkably well.
I see a bedroom system in my future, methinks (now it's time to catch up on my correspondence-school degree in film.)
Posted on: 06 February 2006 by kuma
Margan,
Thanks.
Sounds like it's worth a listen.
Congrats on the n-Vi!
Thanks.
Posted on: 06 February 2006 by Margan
Robbert,
sorry, no possibility to connect a power supply to the n-Vi.
Robbert,
OK, what is the price of the n-Vi in germany?
Posted on: 06 February 2006 by Tuan
quote:Originally posted by David Dever:quote:And is it posible to play stereo?
but NOT enough amplification for home theater application
You have missed the point yet again.
Posted on: 07 February 2006 by Margan
The base price (without FM/DAB and scaler) in Germany is 5000 €.
Posted on: 07 February 2006 by Frank Abela
That's a bit high - it should be 4500 €
Posted on: 09 February 2006 by Chris West
Active Loudspeakers that have electronics inside the cabinet ...
Also generally suffer from gross direct microphony related internal feedback issues. May as well try to crack an egg with a sledgehammer huh?
Hey Dave ... display wasn't so "static" as I was spinning discs and playing music for unsuspecting passers-by in the lobby all through THE show. Many were compelled to stop and listen to the n-Vi/Harbeth combo and were typically very impressed by the sound (and the Naim label music)... especially in the near field naturally.
Posted on: 11 February 2006 by Stephen Tate
hi,
I auditioned an n-vi today, and i have to be honest, this machine is an absolute killer!
Definitely one on my list, i am stunned with everything this machine is about.
A true classic!
regards
A true classic!
regards
Posted on: 11 February 2006 by Rico
quote:but NOT enough amplification for home theater application
eh? Tuan, you really should explain that statement. I suspect you are working from preconceptions or theory, rather than experience. unusually.
Posted on: 11 February 2006 by kuma
quote:Originally posted by Rico:quote:but NOT enough amplification for home theater application
Well, it's not enough for my passive ATC SCM 10s for sure.
Posted on: 12 February 2006 by Mike1380
Certainly more than enough poke to get a Focal Electra package (1027 front, 1007 rear, 1000 centre) driving out MIB and WOTW happily.
Ok, running unity gain through a 202/200 for the fronts was better still.... but the n-Vi was competent enough for them on its' own
Posted on: 22 February 2006 by scala
Hello,
does anyone know the type of Tripath amplifier chip that is used in the n-vi? (And since we are at that, what type of MPEG decoder, DAC, and other major chips?)
