Speaker recommendations
Posted by: murphydog on 02 March 2004
Hello there, I've been lurking and reading posts for a while now and it seems like a pretty helpful list.I have a problem, I have
resurrected my system after some time in storage and would be grateful for suggestions for speakers to audition.System currently comprises:CD3,old skool NAC62,HiCap,160 and its currently driving a pair of first generation Heybrook Sextets in our tiny Cambridge living room.In family terms this is deemed unacceptable.Any feedback would be gratefully received.
Posted on: 02 March 2004 by Sundance
Obviously depends on your budget... but I would seriously take a listen to Neat Mystiques!
..Life has just got better
Posted on: 02 March 2004 by murphydog
Thanks, they are well within my budget,I've set up a dem for next week does anybody have any ideas what I should listen to for contrast?
Posted on: 02 March 2004 by Mike in PA, USA
How about Cerwin Vegas?
Posted on: 02 March 2004 by Steve2701
Try the Proac Tablette Reference 8 Signatures..... amazingly small for that amount of sound.
Posted on: 02 March 2004 by Alex S.
SBLs are a mighty good second hand purchase - you could then climb the whole Naim electronics ladder without having to change the speakers again IMO.
Posted on: 02 March 2004 by NB
This may surprise the forum but I am not going to recommend Neats. Instead I would consider one of the Epos range, perhaps the M15 which works well with Naim gear.
NB
