Internet Radio
Posted by: SteveH on 21 January 2009
Now that I'm of an age when BBC Radio 4 seems to be the only good terrestial radio station in the UK, I'm increasingly listening to Internet Radio.
My favourite at present is Radio Paradise which plays mainly AOR music and doesn't have ads.
It streams at 128k and 192k mp3 and 128k AAC, the AAC stream sounding the best to me.
I'd like to expand my internet radio horizons further, any suggestions?
Posted on: 21 January 2009 by Claus-Thoegersen
If it is something like BBC radio4 NPR is an obvious choice. It is not on radio4 quality level but in my view nothing really is. You can stream it from
http://www.whyy.org/91FM/whyy.asx
This works on my SBR receiver.
Posted on: 21 January 2009 by SteveH
Thanks, Claus
I was also hoping for some suggestions for good music stations
Posted on: 23 January 2009 by Alco
Hi Steve,
May I ask what you mean with AOR music ?
I mainly listen to Radioio.com radio stations.
The quality is reasonable (128k). They do have some (annoying) ads though.
regards,
Alco
Posted on: 23 January 2009 by SteveH
Alco
AOR is a term that used to be used more than now. It stands for Adult Orientated Rock. The term rock is pretty loose as well.
Posted on: 25 January 2009 by Roy T
I listen to bits from soma fm, some consider it a bit West Coast but lots of choice. Works with Windows and works with Ubuntu if using VLC.
Posted on: 27 January 2009 by goldfinch
Bluebit.com streams at high bitrates (I think more than 192) and it is free!
Posted on: 28 January 2009 by Staedtler
Depending on how cheasy you like your music, I like listening to Wave 105 as it plays music from my eras (70's onwards) without overemphasis on the modern rubbish out there.
It does have adverts though which can be very annoying at times...
Posted on: 28 January 2009 by SteveH
I was reminded today about another excellent if eclectic station: FIP from Paris
Posted on: 28 January 2009 by Manu
FIP, yes very good music, but you will enjoy it better if you are not in Paris. Their traffic reports may be quite irritating if you are stuck in them.
Posted on: 29 January 2009 by SteveH
Manu
I have another advantage: my french is pretty poor so I don't understand most of it Winker
Posted on: 30 January 2009 by connon price
My favorite web station is the jazz on 89.9 TSF from Paris. Not AOR, but if you want an alternative. Streams at 128.
Haven't done a lot of searching, though. It is a staff favorite preloaded in Sqeezebox.
