Naim cable experiment
Posted by: RICHYH on 05 March 2003
Further to some questions I asked a few weeks ago I did an experiment on interconnect. From my Snaxo to power amps I removed the Naim cable and installed Run IN Linn analogue (re-terminated as required)( I personally like the Linn cable as interconnect to and from The Grove). It had been on for 2 weeks or so (in my experience no matter what gains you think you hear initially the revalation comes when you change back after a few weeks), so last night I went back to the Naim, and -
Although a less Pin pointed sound, the sound became more alive far more REAL.
Is it now worth trying it as other interconnect and also I have the older Power amp interconnect is it worth upgrading to the lastest type?
Posted on: 05 March 2003 by Wiltshireman
Yes but with Iso-tech 16 amp £70 available from Hi-fi For Sale.com infact replace everything you can (10amp on your CD) you will not regret it!
