nDAC power up sequence...
Posted by: a.diabelli on 08 November 2010
Hi,
can someone one please tell me what it's the right light sequence powering up a DAC?
Mine starts blinking alternately sync and hd lights and later blinks the main buttons five times the most of the times, only rarely it sticks on the last input selected directly.
Anyway, I'm almost sure that my new brand DAC is faulty, it goes out of sync playing files from a digital source after 30/45 seconds, it mutes itself for a second and then plays with sync light off.
If I swap the input to a mute input (let's say number 2) and then come back to the first it syncs and lost sync
after the usual 30 seconds...
It works well only with usb stick playing WAVs.
At first I thought it was a problem of the brand new HiFace Evo I bought at the same time, but now I'm trying a new squeezebox touch and the problem is always here. I was able to make it working well only one time, when it sat on a temporary table, when I power down it and put it back on the rack the problem arises again.
I've tried the usual checks:
. swapped snaic cable with the one from my CD5i
. tried both BNC and RCA cable
. swapped chassis and floating
. changed the main power cable
Any further ideas?
I've bought it directly from uk with the help of a friend who lives there so shipping it back to the reseller it's not so easy (it was not a good idea, first and last time I try to save some money, I swear...)
Sorry for my bad english...
Thanks,
Marco
Any further ideas?
Thanks,
Marco
