How much time do you spend listening to music?
Posted by: Matthew T on 25 July 2002
Posted on: 25 July 2002 by Mike Hanson
I went for 3-8 hours, although it's probably closer to 8+. This isn't all at my "main" system though. However, I think the secondary system in my office needs to count as well. Once I had my "good" main system, the secondary one had to be upgraded to pass muster.
-=> Mike Hanson <=-
-=> Mike Hanson <=-
Posted on: 25 July 2002 by David O'Higgins
Mike, how can you possibly work and listen to music at the same time? Or is the office just a place which you attend because of contractual obligation ?
Posted on: 25 July 2002 by Steve G
I allow music to be played in our office and don't find it effects productivity.
Steve
Posted on: 25 July 2002 by Martin Clark
Not enough!
Posted on: 26 July 2002 by David O'Higgins
Steve, my point is that good music played on a good system (especially Naim) demands your total attention to the exclusion of anything else. In my case it is simply not possible to work and listen to music at the same time.
Posted on: 26 July 2002 by Matthew T
This is depressing. I am probably in the less then 1 hour a day on average of sit down and listen, more as backgorund music.
I must be too busy.
cheers
Matthew
I must be too busy.
cheers
Matthew
Posted on: 26 July 2002 by Mike Hanson
how can you possibly work and listen to music at the same time? ... good music played on a good system (especially Naim) demands your total attention to the exclusion of anything else. In my case it is simply not possible to work and listen to music at the same time.
I know what you're getting at. There are a number of factors aiding me here:
- I'm self-employed, which means there's no one standing over me, telling me to "Get back to work!" Therefore, I can occasionally take a break to listen to a particularly juicy musical tidbit.
- I pick music that I can work by. This varies entirely according to my mood. Sometimes I like intense stuff like Drum'n'Bass, while other times contemplative music like Bach's Goldberg Variations suits my needs. Also, I'm a computer programmer, and I perform a variety of functions (conceptualizing, planning, coding, testing, debugging, etc.). Each of these tasks benefits from different types of music.
- I actually find that I have more trouble staying focused if I'm working in silence. I'm much more likely to procrastinate in those situations. The music helps stay me "in the zone".
- My secondary system is not nearly as good as my main system. If I had my main system in my office, I would get less work done.
I hope that clarifies things.
-=> Mike Hanson <=-
Posted on: 26 July 2002 by andrew mcmullins
I work in a fairly standard office but being a project manager I get out to other offices.
Our marketing team works in what looks and feels like a small flat with the radio on.
I find it makes some types of work (thinking) easier whilst others (planning) more difficult.
I also find the quality of the light makes a difference with flouresent stip lights being the worst.
Andrew
Andrew
Posted on: 26 July 2002 by JeremyD
My LP12 has been cartridge-less for some weeks, so I'm stuck with CD. Hence <1 hr / day
