Leaking shower
Posted by: Dungassin on 05 July 2010
Just spent 30 minutes on the phone talking to the plumber who refitted one of our bathrooms about the shower, which drips after you run and switch off any of the other taps in that bathroom. He'd originally referred us back to the shower manufacturers, who referred us back to him.
Unfortunately he's had a heart attack and is off sick for 3 months. So I rang the bathroom showroom, and spoke to the bloke there, who had already also spoken to the manufacturers.
My thoughts run as follows : Having some understanding of pressures and flows (well, I was a "gasman"), it seems to me that the problem must be that when we run/switch off something, you get a pressure surge which temporarily overcomes the valves in the shower. Specs for shower say OK up to 5 Bar, so either we have abnormally high mains pressure (unlikely as we are on the end of our particular water main), or the shower is outside spec.
Hopefully man in showroom will now be chasing manufacturers to get them to come out to do a "service visit".
All bloody annoying, and you can guess who is getting the brunt of SWMBO's displeasure.
Posted on: 05 July 2010 by deadlifter
Sounds like a faulty shower to me and as with faulty goods your point of contact would be the plumber or the merchants if he was/is employed by them and they MUST sort it. It is not your job to contact the manufactures of the shower
Posted on: 05 July 2010 by fatcat
I could be down to low water pressure. Some valves require a small amount of pressure to seal. When you open a tap, the pressure at the shower valve will reduce. This may cause it to leak. You could try a 15mm non return valve in the shower feed, this would stop loss of pressure in the shower when the taps are opened.
With regards to SWMBO. Tell her since 2009 all plumbing must comply the EU Venice protocol, which states at least one shower in a domestic dwelling must be fitted with a pressure relief valve. Ensures any leaks due to system over pressure won’t flood the house.
quote:could be down to low water pressure. Some valves require a small amount of pressure to seal. When you open a tap, the pressure at the shower valve will reduce. This may cause it to leak. You could try a 15mm non return valve in the shower feed, this would stop loss of pressure in the shower when the taps are opened.
The fitting of check valves is only required where there is a risk of backflow i.e. bath taps with a shower attached, if you fit a check valve on your supply to the electric shower this will lower the pressure that comes out of the shower head
EU venice protocol deals with water saving at source as far as i can tell such as water basins
[reservoirs] as for pressure relief valves these are only to be found on boilers and unvented systems
Posted on: 06 July 2010 by fatcat
quote:Originally posted by deadlifter:quote:could be down to low water pressure. Some valves require a small amount of pressure to seal. When you open a tap, the pressure at the shower valve will reduce. This may cause it to leak. You could try a 15mm non return valve in the shower feed, this would stop loss of pressure in the shower when the taps are opened.
There’s no requirement to fit a non return valve in the feed of a shower, however, if it cures the leaking shower problem, why not fit one. Reduced flow through the shower won’t be a problem, unless the shower is used at present with the control valve fully open.
EU Venice Protocol doesn’t exist. I made the whole thing up. It was just a suggestion to get SWMBO off Dungasins back. Surely the reference to Venice and flooded house was a give away.
However, it is true that due to EU regulations, electric showers are required to be fitted with a pressure relief device. Although, it obviously wouldn’t discharge thought he shower head.
Posted on: 06 July 2010 by deadlifter
Because i thought you were bullshitting i checked on the web and there are protocols for venice concerning water which was why i replied with what i did, and as for prv`s on electric showers the manufacturer possibly fits them internally because it certainly is not on the supply pipe.
When people are asking for advice unless you know a bit about the plumbing industry [ie worked in it] it would be best not to reply to the op as your replys are of no help whatsoever
I was advising Dungasin to bullshit SWMBO. Surely it was obvious.
My advice is aimed at solving the problem.
Your advice
"The fitting of check valves is only required where there is a risk of backflow i.e. bath taps with a shower attached."
Is irrelevant to solving the problem.
He’s already spoken to a plumber for 30 minutes with no joy.
I thought the input from somebody who designed valves for a living would be more useful.
Pressure relief devices aren’t possibly fitted to electric showers, they ARE fitted to electric showers.
Posted on: 06 July 2010 by Julian H
What sort of shower is this?
The problem is the shower its self, there could be flux or boss white/blue in the shower because the plumber has not flushed the pipe work
oh by the way i am a plumber
Posted on: 06 July 2010 by Dungassin
I'm not going to quote - too many individual bits.
1. It's not an electric shower. Connected to cold water supply and the combi-boiler. Shower valve is a Bristan FU MTLSHX C.
2. Quite capable of "bullshitting" SWMBO. Unfortunately she's not particularly susceptible to reason.
3. As the plumber who installed the system is unavailable due to ill-health, I have thrown the problem back at the bathroom showroom. I'll give them to the end of the week, then I'll hassle them again. I have a strong negotiating point, as they know I am proposing to have our other bathroom refitted, and have already had a quote from them.
4. The idea of low pressure as a cause is interesting, but we don't really suffer from that unless all our neighbours decide to use hosepipes at the same time!
5. I must get SWMBO to observe the shower while I open/close other taps in the house to see if that causes the problem as well.
6. I suspect/hope that what will happen is that the bathroom showroom staff will persuade the manufacturers to do a home visit, that they will measure the mains pressure, and then will hopefully supply and pay for the fitting of a replacement shower.
Posted on: 07 July 2010 by Julian H
oh by the way i am a plumber![]()
Dungassin
What deadlifter said is likely to be the problem. I work in the construction industry and we often have to change ceramic valves/cartridges on taps and showers due to contaminated water because systems are not flushed through correctly.
Posted on: 07 July 2010 by Dungassin
quote:What deadlifter said is likely to be the problem. I work in the construction industry and we often have to change ceramic valves/cartridges on taps and showers due to contaminated water because systems are not flushed through correctly.
I'll bow to your professional expertise. That is not a DIY job, and the unit is well within its guarantee period (was only installed in February).
SWMBO has already indicated that for a variety of reasons she does not want the same plumber to do the installation on the other bathroom.
Posted on: 08 July 2010 by fatcat
quote:Originally posted by Julian H:quote:Originally posted by deadlifter:
Dungassin
Julian
Working in the construction industry you will know LTHW systems not only require flushing, but also require balancing.
If a tap can be half opened and closed without causing the shower valve to leak, restricting the flow to the tap will cure the leak.
LOL
An episode of Fawlty Towers springs to mind. Was your plumber called O’Reilly.
Does opening the cold, hot or both taps cause the leak.
How much flow can you get through the taps without the leak occurring
Posted on: 08 July 2010 by Tarquin Maynard - Portly
Have to agree.
If you'd actually said that to SWMBO and she'd checked, your life would be misery.
quote:Originally posted by Mike Lacey:
Have to agree.
Where’s your sense of adventure/humour.
Getting something as obvious as Venice Protocol past SWMBO would be worth the risk. IMO.
Posted on: 08 July 2010 by deadlifter
Mixer showers whether on gravity systems or combi boilers do not need balancing they do it themselves depending on how hot/cold you require the temperature to be. The only balancing to do on hot water systems is when a unvented cylinder is fitted and the you just run a cold water main of the cylinder [where the mains feeds it ]to the bathroom/kitchen appliances
LTHW systems refer to underfloor heating
Posted on: 08 July 2010 by Dungassin
quote:An episode of Fawlty Towers springs to mind. Was your plumber called O’Reilly.
Not O'Reilly. More to do with the fact that he was a heavy smoker, and stopped every half-hour or so for a fag, so he stank of cigarettes (we're non-smokers) and the job took about twice as long as it should have, in our opinion.
Sod's Law means I am unable to do the checks you ask for this evening, as everybody seems to have been using their hosepipes and the pressure/flow through the sink taps etc is rather low/slow ATM. So, this evening no problem apparent with the shower. I'll give it a go tomorrow morning when hopefully the pressure will be back up to normal.
Dungassin, if your shower is passing water constantly there is a problem with your shower valve not your taps or any other item in your house and fitting other valves around the place will not help at all, valves are designed to shut off the supply when not required i.e. closed.
So do not waste time doing other so called checks get whoever you paid for the product in question to come round your property and fix the issue, heart attack or not, in nearly 30 years of being in the plumbing industry i have never heard such utter bollocks as what you are being told to do by people not in the trade.
I take it you were on the tools in the gas so if a gas valve were passing by would you start valving other appliances ?? NO you would realise that there was a problem at the point in question and rectify that.
quote:Dungassin, if your shower is passing water constantly there is a problem with your shower valve not your taps or any other item in your house and fitting other valves around the place will not help at all, valves are designed to shut off the supply when not required i.e. closed.
To repeat, the problem is that there is a short lived leak from the shower head when the other taps in the bathroom are opened and then closed. e.g. The leak occurs for about 3 seconds after the sink cold water tap is closed.
Gasman? I am a retired Consultant Anaesthetist/Intensive Care Specialist. Like all anaesthetists, I have a degree level understanding of the physics of fluid flow. Anaesthetists are commonly referred to as "gasmen" - hence my username here.
Ok understand the dungassin bit now
if that's all the problem is then don't worry about it and don't get valving anything
In the construction industry, and I did specify the construction industry, LTHW is any system typically fed directly from the boilers low loss header. AHU’s, FCU’s, radiators, radiant panels, UFH, ODH’s etc.
Balancing refers to pressure not temperature.
I don’t understand you’re negative responses to my suggestions. All I’m doing is suggesting a few tricks of the TRADE, the TRADE being a building controls designer. I routinely design control systems for LTHW installations containing 100’s of valves.
I may not be a plumber, but I do design the plumbing system.
quote:Gasman? I am a retired Consultant Anaesthetist/Intensive Care Specialist. Like all anaesthetists, I have a degree level understanding of the physics of fluid flow. Anaesthetists are commonly referred to as "gasmen" - hence my username here.![]()
As I see it, opening then closing a tap causes the pressure to drop then rise at the shower valve, causing it to leak. There must be a value of pressure drop/rise below which the valve will not to leak.
Reducing the flow through the tap will reduce the pressure drop/rise. If adequate flow through the tap can be achieved without the shower leaking, problem solved.
You were an anaesthetist. A man afraid of low humidity.
Designed the controls for a few laminar flow unit in my time.
Posted on: 09 July 2010 by Adam Meredith
Judging by the epiphenomenal steam - an absolute shower.
Posted on: 09 July 2010 by Dungassin
quote:As I see it, opening then closing a tap causes the pressure to drop then rise at the shower valve, causing it to leak. There must be a value of pressure drop/rise below which the valve will not to leak.
It's all a bit moot ATM, as Bristan are sending one of their engineers to look at it on 19th July.
Yup, anaesthetists don't like low humidity - at least in the gases that are actually going into the patient. Being a bit of a cynic, I always thought the main benefit of all those antibacterial filters we started using on the ends of anaesthetic/ventilator circuits towards the end of my career benefitted the patient more by helping to humidify the inthaled gases.
Humidity within the actual anaesthetic machine/ventilator is, of course, a bad thing - makes the valves stick etc.
Ah, the "joys" of explaining how fluid logic ventilators work to junior staff/nurses/students ... usually involved a long lecture on fluid mechanics.
