nac 282, power supplies and stageline
Posted by: pjdxpd on 23 December 2009
Hello. i presently have a stageline (new, ie two din connectors). i plan to purchase the nac 282
1) can you use a flatcap 2x with the nac 282 and stageline?
2) i know you can plug the stageline into the nac for power but I'd rather plug it into the second din on the flatcap (while the nac is in the first power supply din).
As i understand it there is a second independent power supply within. Is this possible?
i've been over the pdf's and can't figure it out.
thank you.
pjd@advent.com
Posted on: 24 December 2009 by {OdS}
Hello and welcome to the forum! Can't help you regarding Naim hardware but I can tell you that your thread will soon be moved to the Hi-Fi Corner Winker Have fun.
Posted on: 24 December 2009 by ianrobertm
Yes, I believe you can do that. Something simlar is shown in the Stageline manual:
http://www.naim-audio.com/down..._English_Issue_2.pdf
See Page 7. Just substitute a 282 for the 152. Although, really a 282 deserves better... (like a HiCap).
B Regs,
IanM
