Have bought a NAIT5
Posted by: Bighead on 15 June 2002
Hello,
Just get a NAIT5 to 'replace' my SH Old NAIT2. Several questions for your feedback.
Q1 As there is no phono amp in NAIT2 but NAIT 5, can connect LP to NAIT5 via NAIT2? If so, how?
Q2 Remote can only move up increase the vol but not down(seldomly reduce vol by a little bit)? Do anyone have such experience before? How should I do?
Posted on: 15 June 2002 by Nuno Baptista
Hello:
I´ve got a Nait 5 too!No the control can up and down volum perfectly!Maybe the problem is you have to pull the knob contol volum to you!It was from the package!
Hello:
Posted on: 15 June 2002 by Emil
Check the batteries.
When I received my niat 5, I was able to control all the functions via the remote except the volume. After a few choice words directed at Naim,
I replaced the batteries that are included with the remote. All is fine now.
Emil
Posted on: 16 June 2002 by Bighead
Dear Mark,
Thank you so much. Wow .. Up and down is OK now!!
If I sell my NAIT 2 for 250 ukp(not include the shipping cost), do anyone interest?
Posted on: 18 June 2002 by seagull
my amp is from the old school (i.e. no remote control) I have a question...
When using the remote to change the volume, does the knob rotate as well (on my tv the volume is controlled by an up and a down button)?
Posted on: 18 June 2002 by Peter Stockwell
yes the knob is all singing and dancing.
Peter
