PC Sound problem
Posted by: MartinCA on 06 August 2010
Not really a Naim issue, but ....
I get distorted sound from my PC regardless of:
(1) I play over speakers, headphones, or screen speakers
(2) which sound card is being usind (X-fi or Realtek)
(3) whether I am using iTunes, Windows media or Youtube
(4) what the volume settings are
The only way I avoid distortion is by outputting to the NDAC via an Airport Express
Any suggestions as to what the problem is?
Martin
Posted on: 06 August 2010 by pcstockton
Bad DAC in your soundcard it seems.
Get a new soundcard or USB/spdif converter. I recommend ESI Juli@.
-Patrick
Posted on: 06 August 2010 by MartinCA
I initially thought it would be the sound card too - but its the same for the Realtek as for the X-fi
Makes no sense to me - can't think what else it would be unless there's some setting conflict going on. But where?
Martin
Bad mobo???
Maybe - no other symptoms other mother board problems though.
Posted on: 07 August 2010 by Occean
Have you tried disabling one card in the system properties?
Posted on: 07 August 2010 by MartinCA
Ah - that set me on the right track. There were two different problems which I assumed were part of the same thing. I think the X-Fi card is getting interference (from a relatively new additional disk drive which is sitting too close to it within the case). Whilst the Realtek had 'benefitted' from someone (my son) fiddling with a sound effects setting. With the X-Fi and the Sound-effects both disabled everything returned to normal.
