those "liquid light" projector thingies
Posted by: jayd on 07 January 2004
I want one. Who makes/sells them? Which are the best?
Posted on: 07 January 2004 by Former member
Do you mean like the one in Dev's system picture?
If so, it's made by Mathmos (the people who also do the lava-lamps).
ag
Posted on: 07 January 2004 by Simon Perry
I have one. They are projectors and although quite expensive they are good fun.
Simon
Posted on: 07 January 2004 by jayd
Yeah, those things. For projecting psychedelia on the walls. Seems like the right system upgrade for me at present.
I saw one in a thrift store for $5... couldn't get it to light up, but the motor turned, and it had the liquid disc thing. Should have picked it up and tried to fix it.
We have swapped out the oil filled discs for some of the dotted discs in ours because our son (9 months) gurgles like mad when he sees it.
It's brilliant.
ag
Alex - Dotted disks?
Posted on: 08 January 2004 by Former member
Simon
We got a pack of replacement cartridges and slides from Mathmos. The disks are basically a piece of plastic that is covered with coloured dots against a contrasting background. Current fave is blue dots against a yellow background.
The slides are clear plastic of a single colour, eg purple, and change the colour schemes around.
The effect is a swirling pattern of coloured dots - which is no good if you get dizzy easily Eek
If I remember, I'll take a picture later tonight.
ag
Posted on: 08 January 2004 by Simon Perry
Ooh yes please.
Simon
ag
Posted on: 08 January 2004 by jayd
And it spins, yes? Ohh, gots to get me some o' dat!
Jay
Jay
It spins, and it's possible to change the colours by sticking different filters in there.
All in all, it's blinkin' marvellous.
ag
Posted on: 09 January 2004 by Simon Perry
Looks good.
I shall investigate the packs of additional "refills" to get some of this action.
Are those squares I can see on your wall or the projector?
Simon
Posted on: 09 January 2004 by Former member
The squares are on the wall - part of the nursery decor Wink
ag
