Eichmann Bullet Plugs
Posted by: Goldstar on 14 February 2004
Has anyone tried these rca plug upgrades ?
Robert
Robert
Posted on: 14 February 2004 by davidf
I use the eichmann bayonet plugs to connect my nac a5 cable to my speakers. They make a nice connection. As to whether they enhance the quality of the music, I am not sure... david
Posted on: 14 February 2004 by London Lad
davidf
Where did you get them ?
Graham.
Not a lad any longer and not from London!
Graham.
Posted on: 14 February 2004 by Goldstar
Well, I tried them (using Naim interconnect cable) to connect my Arcam CD Player to the CD input of my 52 Pre.
The plugs are supplied in gold plated or solid silver versions. My dealer recommended using gold versions for the Arcams gold plated output sockets.
These plugs mirror the naim dedicated earth pin system as seen in the Din plug.
Result? Much better, going back to the conventional rca plugs made the music sound confused.
I might add that I only connected earth to one of the bullet plugs.
If you are tempted to try these please let us know the result.
Regards Robert
Regards Robert
Posted on: 14 February 2004 by o.j.
quote:Hy Naimgaim!as iunderstand (reading Eichmann homepage)those plugs use a technical solution similar to naim din plug,but thinking it over logical they bring only the point where the cable mass meets the mass of rca socket alittle bit nearer to the next component in the system. you heard if this works concerning better sound with chinch plugs?
Originally posted by NAIMGAIM:
I'm not a "Tweaker", but they do improve your tunes. A good cheap upgrade is replacing the plugs on your turntable.
I was going to get in some of their banana plugs in to try, but for some weird reason, Audiophile Systems (US Distributor for Eichman) isn't going to stock them...strange, because they stock everything else by them. Looks like I'll have to get them from Canada...eh?
O.j.
got them at VH Audio- the guy is Chris VenHaus
Pnone: 262-650-8280
Pnone: 262-650-8280
Saw now Eichmann bananas on their Page.
looks like annother version of the onepiece banana (like nordost and this expensive wbt type)good idea
O.J.
O.J.
