Where next? 135's or higher
Posted by: AL4N on 27 November 2002
Any comments or views greatfully received!
As a (very) new member to this great forum, any advice on my query would help a great deal.
My system: cdx-82-180-nac05-naim fraim-black snaic.
I have had a pair of 135's on demo for about 3 weeks but am not convinced. Any ideas on my next upgrade cheer's Alan.
Posted on: 27 November 2002 by rocketeer
Hi Alan
when you had those 135s on demo, how did you power your 82? with the 180? if so, no wonder the 135s did not impress you.
i would suggest that a dedicated power supply (hicap or better supercap) for your 82 should definitely be your next step. you'll see, you'll get this recommendation from many others as well, its so obvious...
regards
rocketeer
Posted on: 29 November 2002 by AL4N
With all my haste, I forgot to mention that I have a hi-cap with the 82 and the speakers are JMLab 915
Posted on: 29 November 2002 by Bob Edwards
AL--
I'd put a XPS on the CDX first, or just swap to a CDS2 (or 3 depending on timing/budget). That will make a far bigger improvement than adding a larger/better power amp. Maximize the source, then go the Supercap/52/252 route.
Best,
Bob
Best,
Bob
Posted on: 29 November 2002 by graphoman
Alan Ball said:
I would go...
4. 135's or new Nap250
My system is CDS1/72/Scap/250 and while I know the 72 is the weakest link, my upgrades follows the possibilities (not theories) so it can happen that it’s the 250 that’ll leave the syste, first. That item is a 20-year-old animal, fully re-built in Salisbury for a year or so.
Given a swap+payment, I could go for old 135s or, alternatively, for a 1-year old 250 (demo piece). What do you say to it?
graphoman
I would go...
graphoman
thank you. While I think today’s 250 is much better than mine (better than a pair of old 135s? I wonder), the most I’d like is to upgrade to a 82 or rather 52 but I think I have to wait for another type change by Naim, associated with heavy price drop.
regards
graphoman
regards
graphoman
Posted on: 30 November 2002 by NB
Adding a Pair of 135's at this stage isn't going to give you much of an improvement unless you have demanding speaker.
All you will do is highlight the deficiancies in your front end.
At this stage it would be better to invest into an XPS for your CDX. The XPS really opens up the CDX and provides more control over the rest of the system.
With the new Naim range being released there is a steady flow of second hand XPS's on the market.
Once you have purchased the XPS then look toward replacing the Hi-cap with the Supercap. Then its time to replace that 180.
The 180 is a fine power amp but my only criticism is it does lack a bit of power at high volumes.
NB
NB
Posted on: 30 November 2002 by AL4N
Thank's for the input, I have a hi-cap on the 82 and the speaker's are JMLab 915. After I chnge the speaker's I think an xps will be next, cheer's, Alan
James, the 135's were set up by my local dealer so I asume that this ewas done
Alan
Alan
Posted on: 30 November 2002 by Phil Barry
Could be a bad assumption. Or a miswired speaker. Or even a miswired 135....
Should be a piece of cake to hear the difference between correct and incorrect polarity.
In a square room, it's easy to get bad standing waves. Can you try changing the speaker or listening positions?
Phil
Phil
Posted on: 01 December 2002 by AL4N
I can not change the position of the speaker's due to the room lay-out, it is also the main room with a tv in, so they are stuck were they are
cheer's Alan
cheer's Alan
Posted on: 01 December 2002 by Steve Hall
Depends on funds, but:
1. XPS is a must
2. 2nd Hicap on the 82
If funds are better then:
1. XPS
2. Sell the 82/Hicap and get a 52/SC used
Dump the speakers, and go active!
1. XPS is a must
1. XPS
Posted on: 03 December 2002 by AL4N
Steve, the speaker's can go to-day if only the missus would agree, they "look good" and any-how what would you change them to,assumeing I had the 82/sc
cheer's Alan
cheer's Alan
